Old 03-30-2004, 12:25 PM   #1
TheSnail
TheSnail's Avatar
TheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to all
Quick question on gt25r
Hey guys, I have the 70a/r (0002) gt25r turbo. What is the stock boost set to on this turbo? I dont want to put on the turbo if its set to one bar.
Thank, snail
TheSnail is offline   Reply With Quote
Old 03-30-2004, 01:00 PM   #2
FRpilot
FRpilot's Avatar
stock boosT? i dont think this turbo came stock on most cars. but 6-8 psi like most other stock turbo cars?
FRpilot is offline   Reply With Quote
Old 03-30-2004, 01:43 PM   #3
rcviper
rcviper has a little shameless behavior in the past
Send a message via AIM to rcviper
Does it even have a wastegate on it? If it does it all depends on which model of wastegate got shipped with it.
04 GTO
00 S4
00 S4
1995 240sx S14.5
SR20 Freshly Built Motor, T3/T4, S15 Front
1990 S13 Hatch
SR20 @ 400+ whp SOLD
rcviper is offline   Reply With Quote
Old 03-30-2004, 03:15 PM   #4
PSI240SX
PSI240SX is an unknown quantity at this point
If its a GT25R it will not have a wastegate actuator attached to it. there is no .70 a/r version though as far as I am aware, only .63, and .86. I have the .86 with an HKS wategate actuator and I cannot boost below 10psi. With a stock actuator, you should be able to keep stock boost level (7psi)
www.enjukuracing.com
PSI240SX is offline   Reply With Quote
Old 03-30-2004, 04:29 PM   #5
TheSnail
TheSnail's Avatar
It has an internal waste gate
I am wondering the waste gate factory setting?
#'s on the turbo are 705330-2
Compressor is a 70A/R and turbine is an .86
Here is a pic, just so you dont think im full of crap.
Old 03-30-2004, 04:35 PM   #6
TheSnail
TheSnail's Avatar
Crap 10 psi ! do you think a stock intercooler and fuel is going to be safe?
Old 03-30-2004, 04:40 PM   #7
TheSnail
TheSnail's Avatar
I need to read first... I guess mine is a stock actuator, so I guess mine will be around 7psi. I will just be carfull when I first crank it up for the first time. 00 -> boostgauge
Old 03-30-2004, 04:59 PM   #8
rcviper
That doesn't look like the normal GT25R S trim compressor housing. You might want to find out for sheez that you didn't get a different turbo.
04 GTO
00 S4
00 S4
1995 240sx S14.5
1990 S13 Hatch
Old 03-30-2004, 05:18 PM   #9
TheSnail
TheSnail's Avatar
compressor housing is changed for fitment reasons.
Old 03-30-2004, 05:19 PM   #10
TheSnail
TheSnail's Avatar
The comp wheel is still 2.10"
