![]() Join Date: Aug 2011
Wheels, SR, VVL, KA, Z32, Z33, OEM & aftermarket
Body Kit
S13 BN type 2 body kit SOLD Wheels/brakes/hubs Front 17x8/ Rear 17x9 work stitch wheels $600 Front 18x8.5/ Rear 18x9.5 SSR integral A2 $1,400 front 16x7.5/ rear 16x8.5 $250 Z32 twin turbo set all around 16x8.5 Z32 Twin turbo wheels Chrome $450 240sx 5 lug conversion $250 180sx brakes x2 $75 each S13 4 lugs front hubs $15 S13 front knuckles $20 350Z items cloth seats with s13 rails $350 Z32 items intake Upper and lower twin turbo plenum $150 Custom 2.5" intercooler with dual inlet/outlet $200 (great for 2jz, RB, VG swaps) Throttle bodies $30 each N62 Twin turbo MAF $50 Engine/accs Twin turbo under drive pulley $70 Timing covers $100 2 sets of Twin turbo heads $220 each set 1 Set of non turbo heads $150 2 Twin turbo blocks w/cranks, pistons, rods $300 each block 2 set of 4 Cam Gears$40 each set 1 set of 4 cams 5spd $200 1 set of 4 cams auto $180 2 twin turbo Power steering pumps w/ brackets $50 each electrical EFI harness connectors w/ pigtails $8 per 90 PTU $30 3 twin turbo alternators $50 each tons of coilpacks $15 per Trans/Clutch/Diff Non turbo RPS flywheel/clutch/pressure plate $380 5 spd trans $200 Great for RB25 swaps Twin turbo Rear end, brakes, suspension, wheels, diff etc. $450 Exhaust 2 sets of twin turbo manifolds $30 each Specialty Z 2+2 catback $500 audio Zenclosure for 10'' sub on driver side $60 500 wat Amp $60 Tons of interior parts Fuel 1990 fuel rail $40 old style Nissan side feed 6x 270cc $180 6x 370cc $220 New style side feed 6x 370cc $350 I have tons of interior Z32 items, all interior panels I have are Charcoal (black) 240/180 items KA Engine KA starter $25 #10 ecu 5spd $30 3x KA coils + ignition $25 each KA24de Throttle body $25 oil pan sold plug wires $5 Power steering 2x PS resi $30each Transmission Mount $10 VVL SR throttle body $20 IACV $20 water sensor housing $5 SR20DET oil pan x2 $20 each oil pan baffle x3 $5 each crank baffle x2 $5 each water pump $sold throttle body sold thermo outlet x2 $5 each s13 SR water neck $5 thermo housing x3 $5 each water temkp sensor housing x2 $25 fuel rail sold exhaust mani x2 $40 each clutch fan (minus the fan just the clutch part) sold water pump pulley sold dipstick tubes x2 $5 cross over tube $5 oil catch can OEM x2 $15 each intake manifold bracket $5 knock sensor x3 $20 oil return tube $5 power steering mount bracket sold alternator mount adjuster $5 timing chain tensioner x3 sold oil filter housing x3 $15 each clutch slave $5 oil pump drive $5 timing chain gear $5 IACV sold Alternator bracket 20 power steering mount $12 starter sold MAF sold upper & lower intake mani $30 HKS 90 degree filter pipe $15 redtop 02 sensor SOLD radiator $50 (aftermarket jdm) S13 block w/ crank $150 eagle rods w/ bearings $320 SR20VE head SOLD CAS sold E5 ecu x 2 SOLD 62 ecu x 2 SOLD Megan Down pipe sold HKS down pipe SOLD s13 sr20 redtop motorset w/o turbo $1,400 SR EVO 8 turbo setup $620 s13 power doors $150 s13 wingless hatch x2 100 each s13 popup hood x2 $75 each S13 gas tank $50 s13 RUCA's pair $20 S14 toe arms $20 S13 front LCA's x2 pairs $30 each S13 manual doors $60 S13 tension arm brackets $30 S13 front cross member x2 $40 each S13 rear subframe x2 $50 each S13 carpet $50 S14 carpet $50 S13 Tein Tension Arms $80 S13 SR koyo Radiator sold Bee*R rev limiter $200 S14 steering rack $75 S13 hicas steering rack $100 S13 welded diff $75 S13 brake pedal x3 $40 each S13 clutch pedal x2 $40 each S13 5spd driveshaft x2 $100 each Personal (wooden) steering wheel $100 screamer Pipe SOLD S13 A pillar panel $10 S13 gauge cluster surround x 4 $20 each S13 shifter trim $10 S13 kick panels $15 S13 glove box $15 S13 center console x 2 $30 each S13 steering wheel shrouds x 4 $20 each S13 hvac $40 electronic items have been tested and are in working shape sold as is no refunds sorry Willing to ship add 3% for Paypal 914 382 2116 [email protected] First come first serve. $ talks. Sent from my SPH-L710 using Tapatalk 2
www.NYZC.net Last edited by Supergoji; 11-10-2012 at 01:26 PM.. |
Yes, what are you looking for
www.NYZC.net |
![]() Join Date: Jun 2003
Trader Rating: (130)
Info on the vvl head. P11? P12? Complete or bare? Has cams? Pix?
Efaustin and brndck pm's sent
www.NYZC.net |
all pms responded!
the wheel shrouds are for the steering column they look like this http://autotechimports.com/inside/up...12DSCF1620.JPG (not my picture) but mine are all clean
www.NYZC.net |
I have received all texts and pm's, I will respond tonight. I have been extremely busy.
www.NYZC.net |
#17 |
all sold items shipped
list updated and all pms replied!
www.NYZC.net |
#21 |
all ecu's were tested and were working fine
daughter board i was unaware of i will accept the daughter board ecu back but the "burnt one" is on you as they all worked fine before shipping out
www.NYZC.net |
#22 |
No. The burnt one isn't on me. It's on you. You sent it to me, you take it back. You say you checked them, but yet you were unaware that one has a daughterboard.
Clearly burnt. Even has solder to the left on the one pin like someone would have tried to fix it at one point. ![]() Clearly a daughterboard installed. ![]() |
#23 |
damn that's crazy, he was testing them when i went to pick up my part so i was interested in one but he didn't have a J4, he indeed did test em out in front of me, i was gonna buy one to resale it on the bay.
#24 |
as seen above
i put them in my car one at a time and drove around block with them they worked fine all of them were also given a full throttle rip down the street they all worked fine when they left my possession like i said i will take back the daughter board ecu no problem
www.NYZC.net |
#25 |
yeah, I'm at school so its yet to go in any car or mine. but it can easily seen by opening it that its junk.... and the fact that he didn't know one had a daughterboard is telling me that he didn't check any.
#27 |
i TEST inside car by DRIVING with it
i have spoke to paypal and informed them that everything was sold as is which was stated at the bottem of my post if you like i can involve the witness that saw all 4 of the ecu's working fine
www.NYZC.net |
#30 |
i have both
which do you need and sure ill ship
www.NYZC.net |
