Old 08-24-2009, 08:20 PM   #1
nurvcom
nurvcom's Avatar
nurvcom is an unknown quantity at this point
Send a message via Yahoo to nurvcom
RB20DET Not Starting
OK
Specs
91 240sx
Rb20det (stock)
Picked car up already swapped and it start a few times now it wont
All the motor will do is Crank crank crank crank and not start not even a sputter or anything
What i checked and fixxed when this started happening
1.Wire harness was all Messed up so i think i fixxed it
2. CAS was bad so replaced New Used one Tested and works on other Motor
3. ECU was good but got Another unit just in case Both ECU was checked and work perfect
4. Check all relays and fuses all bad was replaced
5. Check all Grounds on Motor and ECU and i added some more grounds
6. Check Fuel pump (255 walbro) primes and works perfect fuel PSI is OK
7. Coils and Injectors are working
you think it mite the key switch on steering column?
I cant Figure this out and driving me crazy
nurvcom is offline   Reply With Quote
Old 08-27-2009, 08:54 AM   #2
nurvcom
nurvcom's Avatar
bump no one knows :
o and IGN chip was replaced
Old 08-27-2009, 08:58 AM   #3
240love
240love's Avatar
240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection
vacumm leak?
240love is offline   Reply With Quote
Old 08-27-2009, 09:29 AM   #4
nurvcom
nurvcom's Avatar
Originally Posted by 240love View Post
vacumm leak?
i checked all vacumm lines non are unhooked
Old 08-27-2009, 09:31 AM   #5
flawlessflo3190
flawlessflo3190 will become famous soon enoughflawlessflo3190 will become famous soon enoughflawlessflo3190 will become famous soon enoughflawlessflo3190 will become famous soon enough
ignitor grounded?
flawlessflo3190 is offline   Reply With Quote
Old 08-27-2009, 09:36 AM   #6
nurvcom
nurvcom's Avatar
Originally Posted by flawlessflo3190 View Post
ignitor grounded?
i grounded the grounded the wire do i need to ground the ignitor case to something?
Old 08-27-2009, 09:41 AM   #7
240sxxs
240sxxs's Avatar
240sxxs is an unknown quantity at this point
what about fuel problem.
The pretty one Arn't free and the free one Arn't pretty
240sxxs is offline   Reply With Quote
Old 08-27-2009, 09:43 AM   #8
240love
240love's Avatar
there could still be something leaking.. back when i had my rb20 it wouldnt start if it had the slightest leak
Old 08-27-2009, 09:45 AM   #9
nurvcom
nurvcom's Avatar
me and my friend check fuel pump it working perfect and fuel filter is clean and not clogged
No on the fuel line going to the motor
Top line on intake on RB20DET Feed
and
Bottem Line on intake on RB20DET is Return
Correct?
Old 08-27-2009, 09:57 AM   #10
240love
240love's Avatar
did you ever disconnect the fuel lines? if you did make sure you put them back correct cause that shit happens all the time lol
Old 08-27-2009, 10:19 AM   #11
nurvcom
nurvcom's Avatar
ok i check fuel lines today
Old 08-27-2009, 07:39 PM   #12
nurvcom
nurvcom's Avatar
ok check fuel line It hook up right still not starting Took A compression test
Front 6 130psi
Front 5 130psi
Mid 4 130psi
Mid 3 130psi
Rear 2 140psi
Rear 1 140psi
ok
Pulled coils and checked them agine
each coil fires fine
and
injectors working fine cuss it floods after 5 or 6 time trying to start it
Half Mood (F#$King) Key Broke off cam so now it kinda hard to reinstall cas
and it still not starting
well I think i going to fuxking give up it not whatting to work and i put so much into now i am pissed
Old 08-27-2009, 07:42 PM   #13
soon2bs13
soon2bs13's Avatar
soon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-known
Send a message via AIM to soon2bs13
you have not checked the battery or starter yet?
mine was giving me issues as well. check the starter clip. the connector that is probably loose or is not making contact. i had to redo mine because it would not start at all.
i also had an odyssey battery that died on me, bought a stock one that would fit in the engine bay and i haven't had issues as of lately.
don't give up!
neg repping is cool!!
soon2bs13 is offline   Reply With Quote
Old 08-27-2009, 07:46 PM   #14
nurvcom
nurvcom's Avatar
don't give up!
Ok battery is Good holding over 12.something volt and i am wearing it down recharging it to keep working on it
ok starter Clip?
Starter not loose
it crank crank cranks cranks when battery low it crank crank stop crank crank stop crank
Old 08-27-2009, 07:48 PM   #15
nurvcom
nurvcom's Avatar
oo and i got new spark plugs what the stock GAP? for RB20det?
Old 08-27-2009, 08:19 PM   #16
soon2bs13
soon2bs13's Avatar
ok starter Clip?
Starter not loose
http://i149.photobucket.com/albums/s...Photo-0063.jpg
not the picture i was looking for, but it is too dark out for me to take a picture to show you. you have the bolt for the ground and the male pin for the power. the female connector is what possibly could be loose or not making a good connection, if it is on there and you have a butt connector, that could be your issue to. my butt connector was not crimped down good enough and it pulled right off.
i forgot what i gapped mine to. i believe it is .037 inches, but do not quote me on that
Old 08-27-2009, 08:50 PM   #17
nurvcom
nurvcom's Avatar
ok i guess it some it some kinda of signal wire to tell ECU car is starting or something
sorry if i Sound Stupid
i usally Good with cars it just this motor that got me I am a honda guy i still have a 95 RHD civic coupe with a built b18B LS swap
i guess your close i did a search and found tons of people on nico and here using this gap on rb20 and rb25
.032
Old 08-28-2009, 08:09 AM   #18
soon2bs13
soon2bs13's Avatar
.032
I am not sure the correct name of it either. haha. You don't sound stupid. Had I not done this swap and had some issues, I would not have been able to help. ;-)
I am a Honda guy myself. 2002 Civic Hatch with Greddy kit and I am nearly done building another motor (K20a2)
What plugs did you buy? I was told to buy the 300zx Turbo spark plugs.
Old 08-28-2009, 05:00 PM   #19
nurvcom
nurvcom's Avatar
well i tryed messing with starter still Crank crank crank not even a sputter or cough
Old 08-28-2009, 05:16 PM   #20
soon2bs13
soon2bs13's Avatar
Crank Sensor?
My Honda's Crank Angle and Cam Sensor went out and the car wouldn't do crap...wish you had a video or if i was close enough i could look at it at least...lol
Old 08-28-2009, 05:22 PM   #21
RastaS13
RastaS13's Avatar
RastaS13 is an unknown quantity at this point
Bro it sounds like a ground. Happened to me and it took us forever to figure it out.
Skank it
RastaS13 is offline   Reply With Quote
Old 08-28-2009, 10:35 PM   #22
nurvcom
nurvcom's Avatar
I dont know what Ground i check all ground wires and Made like 6 extra grounds for the engine and one for ecu
CAM sensor new Used and all injectors fires and coils fires fine
Old 08-29-2009, 02:38 PM   #23
nurvcom
nurvcom's Avatar
hopefully if i can get my camera working i take a video
Any new ideas on what Should i check ???
my motor is somewhat apart
Coil and plug pulled
I checked all vac
Does Fuel rail have 2 FPRs? one on each end ?
Everyone when i Got this car it ran and started only 5 time
i got it with rb20det already swapped into car...
What I have Done in parts
harness repaired
new used cas other one was bad
new plugs
new used ECU
how many sensors are on the rb20det?
Would any sensor make the car not start???
all it does it crank over but no sputter or coughing at all!!!
Old 08-29-2009, 03:37 PM   #24
GSXRJJordan
GSXRJJordan's Avatar
Proper gap is ~.030", so that's not the problem.
The wire you're looking for is orange with silver hash marks from the dash harness (I assume it's an S13), and goes to the ECU to give +12V whenever you're cranking the car. The car should start without it, if you pump the gas and crank it a few times, so I'm guessing that's not the problem. Anyway, check to make sure you have +12V at all the applicable pins using the wiring diagram:
The pin locations are from THE BACK of the ECU harness most of the time - you can check because the '100' pins are physically larger than the rest.
Old 08-30-2009, 12:47 AM   #25
nurvcom
nurvcom's Avatar
YA
ECU red light go's out when cranking car that should stay on? meaning that ecu stay's on
Old 08-30-2009, 02:45 AM   #26
GSXRJJordan
YA
My guess is you've got your ECU wiring wired up directly to the ignition switch, and you're using an 'Accessory' wire instead of the black/white (or black/red, depending on where you grab it) 'Ignition' wire. Use a multimeter with a probe on your "ignition-switched +12V" leads on the ECU, see if they drop to no volts while you're cranking.
Old 08-31-2009, 04:28 PM   #27
nurvcom
nurvcom's Avatar
well My multimeter stopped working
and check wire it looks good to my eyes Man this car is first to discourage me
ok i talked to the guy who use to own the car with rb20det he swapped it in
He said it was working find and all of a sudden it just died and didn't what to start and he only got it to start a few time after and i got it to start a few time to
Old 09-01-2009, 02:40 PM   #28
nurvcom
nurvcom's Avatar
U think it Could be my harness got a problem?
i tryed to change some wires and it still doesn't start only crank crank
This car would start every once and wile and run but once warm it would Die and now it just quit ....
Old 09-01-2009, 03:48 PM   #29
GSXRJJordan
All the information you need to diagnose the problem is in this thread.
Once you figure out where the problem is, I will try and give you some tips on how to fix it.
Old 09-01-2009, 03:52 PM   #30
omgshawn
omgshawn is an unknown quantity at this point
Have you tried retiming it?
omgshawn is offline   Reply With Quote
