Old 03-01-2004, 07:38 AM   #1
four
four's Avatar
four is an unknown quantity at this point
Send a message via AIM to four
SR SAFC Deceleration Setting help
I programmed my safc to work with the atmospheric BOV i have. However, on a cold start, it idles very bad, and if i dont give it gas, it will stall.
When the engine is warm, then my car idles just fine, no problems whatsoever. My only problem is cold-starts in the morning, or during the day if i park somewhere for a while.
My car is an s14 w. a redtop
My current DECEL - Air readings are as follows:
Thr - .9%
NE1 - 1.4
NE2 - 1.9
Thanks in advance for anyone that can help.
four is offline   Reply With Quote
Old 03-01-2004, 07:42 AM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
I just played with the NE1 % untill the cold start idle was bareable. Around 2.3+ worked for my hacked MAF KAT. With the S-AFC and an open atm BOV you're pretty much stuck with either crappy cold start idle or dead idle after deceleration. It's hard to find a happy medium....
AceInHole is offline   Reply With Quote
Old 03-01-2004, 07:45 AM   #3
four
four's Avatar
Cool, thanks for the quick reply.
I know its possible, because a friend of mine had it on his setup, but he doesnt remember what he had for that setting. (he sold the s-afc and got a power FC)
what is your complete readings?
Thr?
ne1 - you said was 2.3
ne2?
IIRC, it says on the manual that ne1 must be less than ne2
thanks again in advance
Old 03-01-2004, 07:52 AM   #4
AceInHole
Autox Technician
AceInHole's Avatar
I'm not sure if the manual said what it was supposed to say... there's a lot that seems lost in translation.
My NE2 was set to like .5 or something. The settings I used most were like:
Thr: 0.4%
NE1: 2.5%
NE2: 0.5%
It will most likely be a bit different for your car, though.
Old 03-01-2004, 08:04 AM   #5
four
four's Avatar
What setup are you running? Do you have a KA-T or SR?
Edit:
Also, what are your ne1 and ne2 RPM settings?
I think this is where i F*ed up
Old 03-01-2004, 08:29 AM   #6
AceInHole
Autox Technician
AceInHole's Avatar
I'm running a KAT. NE1 = 1000rpm, NE2 = 3000. I'd rather have them closer together but I did this for more resolution up top where I need it more (SAFC II v. 1)
Old 03-01-2004, 08:33 AM   #7
four
four's Avatar
Yea, thast where its different because i dont think my gap is that much.
I guess ill try to mess with it again, and re-tune.
Thanks
Old 03-01-2004, 12:08 PM   #8
four
four's Avatar
okay, i pretty much tried re-tuning it...basically until the idle doesnt bogg on me anymore..and it seems you cant get it somewhere in the middle..you're right...when i deacelerate...it still sort of hops down rpms, then goes to where it belogs...but its not as bad as before...
im gona keep trying to fine tune...i didnt get to really do it well because by the time i was getting somewhere with the tuning, the engine warmed up...hopefully i can solve this by tonight
Old 03-01-2004, 02:58 PM   #9
Soulja
Soulja is an unknown quantity at this point
I always wondered, why not place the MAF on the cold pipe, after the BOV, that way is not metering the air that being vented?
Soulja is offline   Reply With Quote
Old 03-01-2004, 03:14 PM   #10
four
four's Avatar
because tahts custom work haha
Old 03-02-2004, 07:47 AM   #11
four
four's Avatar
---Bump---
Old 04-16-2004, 09:09 PM   #12
Touring240
Touring240 is on a distinguished road
bump for an old thread
did you ever get some settings worked out dec air on your red top? if so what were they? thanks
Touring240 is offline   Reply With Quote
