Old 04-10-2013, 01:36 AM   #1
drkz33
drkz33 is an unknown quantity at this point
98 S14 Complete KA24DE Engine & Auto Trans w/ECU & Harness
PLEASE NOTE: THE ENGINE / TRANSMISSION / HARNESS / ECU SET-UP HAS BEEN SOLD, THANKS TO ALL FOR THE INTEREST !!!
"MODS PLEASE LOCK THIS THREAD UP"
Up for sale is a 1998 (S14) Complete KA24DE Engine & Automatic Transmission w/ECU's (trans & engine) & Harness w/80k miles. This engine was taken out of a parts car and was running at the time of removal. The engine and trans are in both perfectly working condition. I also took several videos showing the engine running, mileage and did a compression test to show all cylinders read 170 psi across the board. The engine & transmission will come with every sensor imaginable including the entire engine harness from the cabin to the engine bay and the transmission harness as well.
It will also come with all that is pictured below which is the intake & exhaust manifold, motor & trans mounts, distributor, spark plug wires, injectors, throttle body, alternator, stater, AC compressor, AC lines, power steering pump, p.s. lines, coolant hoses etc. etc, the list goes on and on. To top this list off, every single sensor and part is in working condition and the bonus is the oil and transmission pan is free from dents. All you need to do is bolt this right into your car and your good to go.
I'm looking to get SOLD for the entire set-up and it's located in SoCal. Thank you for your time and the space Zilvia !!!
drkz33 is offline   Reply With Quote
