Old 09-24-2008, 10:17 PM   #1
CoreyS13
CoreyS13 is on the path to ruinCoreyS13 is on the path to ruinCoreyS13 is on the path to ruin
Abs
If I was to ditch ABS would I just have to find some non abs 240sx and use those lines to replace the ones that lead to the unit? Give me some feedback on what I could do.
CoreyS13 is offline   Reply With Quote
Old 09-24-2008, 10:20 PM   #2
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
Not sure but what I do know is that your going in the right direction threshold breaking is where its at =]
s13 @ fullboost is offline   Reply With Quote
Old 09-24-2008, 10:25 PM   #3
CoreyS13
There was another thread on this, yes I did search. But it was full of just bickering and nothing was actually accomplished/answered to ensure of what should be done.
Old 09-24-2008, 10:40 PM   #4
Def
Keep ABS - flatspotted tires suck. You can still threshold brake with ABS, it's more of a "cover your ass" in case you hit a bump or something and lock the tires up.
Old 09-24-2008, 11:21 PM   #5
Dousan_PG
Dousan_PG's Avatar
yeah, new liness and not sure on bmc issue
i changed a car i had once
easy street
Aaron
Pink GodziRa
Old 09-25-2008, 08:27 AM   #6
cdlong
you have to add a splitter to the front brake line or get a non ABS MC, which shouldn't be that hard, because it already has two front line ports.
or you could do like Def said and leave it.
cdlong is offline   Reply With Quote
Old 09-25-2008, 09:43 AM   #7
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
I WISH I had ABS. I have flat spotted sooo many tires....
ryguy is offline   Reply With Quote
Old 09-25-2008, 10:09 AM   #8
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
try to learn tap brake. it helps.
Old 09-25-2008, 10:35 AM   #9
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
I love my ABS brakes. I would never get rid of them.
garagelu is offline   Reply With Quote
Old 09-25-2008, 10:40 AM   #10
spikNspan
spikNspan's Avatar
spikNspan has a spectacular aura aboutspikNspan has a spectacular aura aboutspikNspan has a spectacular aura aboutspikNspan has a spectacular aura aboutspikNspan has a spectacular aura aboutspikNspan has a spectacular aura about
Send a message via AIM to spikNspan
when you feel the tires start to slip let off the brake... self abs.
spikNspan is offline   Reply With Quote
Old 09-25-2008, 10:40 AM   #11
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
I just got rid of my ABS. easy as pie. Get non ABS hardlines and a non-ABS BMC, and just swap everything out. Took all of 10 minutes.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 09-25-2008, 12:25 PM   #12
CoreyS13
Did you find the hardlines/master cylinder at a local wreckers or brand new? Price wise how much did it cost.
Old 09-25-2008, 10:07 PM   #13
cdlong
you have three brake pedals and can control them individually? cool.
Old 09-26-2008, 11:07 AM   #14
Slammed180
Buddy had the S13 BMC - $60.
Another buddy had the hardlines - $60
Then I bought a Z32 BMC - $95.
These are all RHD parts, so they were harder to find and more expensive, but generally it cost $150
Blow me, bitches.
Old 09-26-2008, 11:33 AM   #15
SnakeKack
SnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of light
Send a message via AIM to SnakeKack
You could just unplug it. That's what I did. Only problem is the abs light stays on.
My ABS was f'd up though so that's why I did it.
SnakeKack is offline   Reply With Quote
Old 09-26-2008, 11:33 AM   #16
ZX88
ZX88's Avatar
driving with out abs is easy as pie. just tap the brakes instead of holding them. arent the pads different?
Old 09-26-2008, 08:37 PM   #17
cdlong
a lot of the hardware is different, depending on year. the rotors and booster are different in addition to everything already mentioned.
Old 09-26-2008, 09:03 PM   #18
SlideWell
SlideWell's Avatar
SlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfection
you could... however its nice to remove the heavy ABS unit and free up space in the engine bay. makes for a cleaner look in addition to weight reduction.
SlideWell is offline   Reply With Quote
Old 09-26-2008, 10:19 PM   #19
ryguy
ryguy's Avatar
I'd like to see you tap the brakes when you are going to drive up the ass of some elderly guy who just pulled out in front of you. I laugh when I think back to driver's ed, when they tell you to "tap the brakes in a panic situation if you don't have ABS." Its just not something you think to do in a split second situation.
Old 09-26-2008, 10:23 PM   #20
SlideWell
SlideWell's Avatar
its how you are connected to the vehicle you are driving. you either know what to do or you dont. it happens naturally or it doesnt. ive had cars with ABS and no ABS and subconsciously performed the right operation.
