Old 03-25-2013, 08:22 PM   #1
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
HKS-AEM-ARC-RacePak-TONS MORE! NEARLY 100 NEW and USED PARTS FOR SALE!
PRICES ARE FIRM AND THE ONLY THING I'LL TRADE FOR IS MONEY!
ARC 8000R switch panel WITH an extra relay/fuse unit and cable
- BRAND NEW IN BOX!
- $275 - SOLD!!!
HKS EVC VI Boost Controller
- BRAND NEW IN BOX!
- $650
AEM Series 2 Standalone EMS for SR20DET 91-95
- BRAND NEW IN BOX!
- $1,350
RacePak Vnet EFI Interface Module for AEM
- This allows you to hook up an AEM ecu to a RacePak cluster
- BRAND NEW IN BOX!
- $375
Votion Liquid to Air Intercooler Kit
- Capable of supporting up to 800+hp
- BRAND NEW IN BOX!
- Kit includes: 26X7X3.5 Heat Exchanger, Fill Cap, Ice Box, Bosch pump, Dual 7" fans, 15X6.5X6 Long Flow Intercooler
- $750
Axxis S13 Ceramic Front Brake Pads
- BNIB
- $40 - SOLD!!!
S14 A/C Bezel
- All tabs are broken
- $10 - SOLD!!!
SR Timing Chain Tensioner
- ~3k miles
- Perfect Shape
- $30
Cam Angle Sensor Gasket and O-ring
- Perfect Shape
- $5
Intake and Exhaust Cam Gear Bolts
- PERFECT SHAPE!
- $3 each
SR20 Head Bolts
- Used
- $15
KU Engineering S13 Intake Manifold
- Never Used (just sitting around for about 3yrs, but the last owner drilled injector port 1 larger to put larger injectors in but then sold it to me...costs about 60 to do it to the other 3 or 40 to correct port 1)
- $110
SR20 Upper Oil Pan - SOLD!
SR20 Oil Pump - SOLD!
SR20 Oil Screens (2 sets)
SR20 Rear Crank Case Cover (4)
SR20 Oil Block Galley w/ Sensor - SOLD!
Unknown Brand BOV
- Slightly Used
- PERFECT SHAPE
- $50
SR Main Cap Girdle
- PERFECT SHAPE
- $15 each
SR Coolant Tubes - $20
SR Short Coolant Tubes - $5
SR Temp. Sensor Housing - $10
SR Thermostat Housing - $10
SR Coolant Inlet - $10
SR Coolant Complete Setup w/ Sensors - $45
OEM SR20VE P11 Valvetrain (IN+EX Valves, Springs, Cams, Gears)
- 15,000 Miles
- PERFECT!
- Valves - SOLD!
Springs - $25
Retainers - $15
Camshafts - $50
Gears - $10
SR20DET AAC Valve
- PERFECT SHAPE
- $30
S14 SR Valve Cover w/ Coil Pack Cover
- Perfect Shape
- $160
stock KA24de airbox intake system and Filter is still clean (came from a 98' kouki)
- PERFECT SHAPE
- $50
S13 Non-ABS Driveshaft - Pick up only
- Used
- $90
S13 SR Transmision - Pick up only
- Roughly 30k miles
- PERFECT SHAPE
- $140
S13 SR20 Intake Gasket
- PERFECT SHAPE
- $10
S13 SR Bell Housing
- No cracks
- $40
S13 SR release bearing
- Good Condition
- $10
S13 SR Clutch Fork
- Perfect Shape
- $20
SR20 Timing Chain guide
- Perfect Shape
- $10
S13 SR Valve Cover Baffeling
- Great Shape
- $10
SR20 Coilpack Gaskets
- NEW
- $3 each
S13 SR20 Valve Cover Gasket
- Perfect Shape
- $15
Injector Gasket O-rings
- Perfect Shape
- $3 each
SR20 Rear Main Seal
- New In Box
- $18
(8) SR20 Hydraulic Lifters
- Perfect Shape
- $5 each
SR T3/T4 Exhaust Manifold
- NEVER USED
- $90
SR OEM Exhaust Manifold
- Perfect Shape
- $40
SR20det Exhaust Gaskets (t3, T4, Exhaust mani)
- Perfect Shape
- $20
Crank Pulley Bolts (2)
-Perfect Shape
-$5
Transmission Mount Brackets
- Perfect Shape
- $15 each
Nismo KA/SR Transmission mount
- Perfect Shape
- $65
Alternator Brackets
- Perfect Shape
- $20 each
Knock Sensor (4)...one doesn't have a sub-harness
- Perfect Shape
-$25 each (15 for the one without the sub-harness)
Godspeed Arm - $15
S13 Rear Links - $10 each
S13 Front Lower Control Arm - $30
(2) o2 Sensor Simulator
- one was touched with dirty hands, then I put on gloves
- NEW IN BOX
- $33
\/ \/ \/ 350Z PARTS \/ \/ \/
350z LSD
- ~15k miles
- $200
350z Master 1 1/16th
- Perfect Shape
- $45
350z Brake Booster
- Perfect Shape
- $100
350z Arms
- Perfect Shape
- $50
350z 03' tinted tail lights
- Great shape
- $75
These are all the make an offer items...i dont want or need them so just make an offer...pictures of these upon request.
\/ \/ \/ 2005 WRX (less then 20k miles on items)\/ \/ \/
OEM Air Box Setup
OEM Downpipe
OEM Full Exhaust
OEM Uppipe
OEM Turbo Heat shield
\/ \/ \/ Auto 200SX SER Engine Part Out \/ \/ \/
Head (currently has valves, springs, retainers, and keepers but can remove if buy requests)
Rocker arms
Oil tubes in SR head
Intake and Exhaust cam gears
Valve Cover
EGR valve (in WORKING order)
distributer (in WORKING order)
Headers
Injectors w/ Fuel rail
Intake Manifold (perfect Condition w/ all connectors and hoses)
(3) Pistons
(3) Rods
Water Pump
Water Pump pulley
oil filter block
crank pulley
Coolant tubes
Coolant outlet
Lower Oil Pan
Oil Pan baffling
Timing chain tensioner
Flex Plate
Auto trans gasket
Alternator bracket
intake bracket
power steering bracket
ac bracket
Auto 200sx Engine Harness (completely uncut)
injector harness
tps (throttle position sensor)
Thank You For Looking!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 03-25-2013, 08:51 PM   #2
HanzdeFuko
HanzdeFuko is on the path to ruinHanzdeFuko is on the path to ruinHanzdeFuko is on the path to ruin
Where u located interested in intake manifold
HanzdeFuko is offline   Reply With Quote
Old 03-26-2013, 07:30 PM   #3
Imarvin240
Trader Rating: (18)
More parts added!
Old 03-26-2013, 10:36 PM   #4
2jzgtes14
2jzgtes14 is an unknown quantity at this point
sr tb
Do u happen to have a tb for the s13 Sr? Text me 9794021256
2jzgtes14 is offline   Reply With Quote
Old 03-27-2013, 06:56 PM   #5
HanzdeFuko
Txt me 60101033
Old 03-27-2013, 09:34 PM   #6
thizzen4
Trader Rating: (22)
thizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymore
Feedback Score: 22 reviews
pm me if u still got the mannifold im interested
thizzen4 is offline   Reply With Quote
Old 03-27-2013, 10:44 PM   #7
jmax240
jmax240 is an unknown quantity at this point
His location says King of Prussia which is an actual place he's not just being sarcastic lol. It's like a 20 minute drive northwest of Philly.
4 SALE intercooler mafs valvecover rep fn01rc http://tinyurl.com/jmaxzilvia
jmax240 is offline   Reply With Quote
Old 03-27-2013, 10:45 PM   #8
jmax240
Do you work at a shop around KoP? I've seen your for sale threads and you always have a ton of stuff!!!
Old 04-03-2013, 09:59 PM   #9
Imarvin240
Trader Rating: (18)
Nah, I just build a lot of stuff for myself hah. I will be adding a bunch of parts in the next couple weeks!
Old 04-06-2013, 12:20 AM   #10
justinstamp
justinstamp is an unknown quantity at this point
Need the sr20 valve cover gasket how much shipped to 28043 shoot me a text 8283050333 need it asap thanks
justinstamp is offline   Reply With Quote
Old 04-17-2013, 10:24 AM   #11
95 Zenki
95 Zenki's Avatar
95 Zenki is on the path to ruin95 Zenki is on the path to ruin
Waiting on your Paypal address payment is ready to be sent ,, let me know
ARC relay panels mine
95 Zenki is offline   Reply With Quote
Old 04-17-2013, 01:22 PM   #12
enriquetc240
enriquetc240 is an unknown quantity at this point
Pmed about intake mani
enriquetc240 is offline   Reply With Quote
Old 04-17-2013, 10:01 PM   #13
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
what throttle body fits that intake manifold?
Old 04-17-2013, 10:36 PM   #14
PureRush
PureRush is an unknown quantity at this point
How much for the 350Z Carbon Fiber Hatch?
PureRush is offline   Reply With Quote
Old 04-18-2013, 01:58 AM   #15
xinfinitix240sx
xinfinitix240sx's Avatar
xinfinitix240sx is an unknown quantity at this point
Send a message via Yahoo to xinfinitix240sx
Bump nice stuff
xinfinitix240sx is offline   Reply With Quote
Old 04-18-2013, 08:00 AM   #16
Drift_FX
Drift_FX's Avatar
Drift_FX is an unknown quantity at this point
hey you might want to lower your price on the air to water kit since you can get everything from votion brand new for about $525
Drift_FX is offline   Reply With Quote
Old 04-18-2013, 08:35 AM   #17
Imarvin240
Trader Rating: (18)
they don't sell all these items together as a kit. If you email and ask them to put all these items together as a kit, it comes out to be about $800. trust me, I know, I did that.
Old 04-18-2013, 08:46 AM   #18
Drift_FX
Drift_FX's Avatar
they sell a kit that is missing 1 fan and the ice box.... $389
TYPE 5 Water to Air Intercooler Kit - Basic
additional fan $25
Universal Slim Radiator Fan Kit
ice box $99
Water-to-Air Ice Box Reservoir
total $513+tax/shipping
unless im missing something? it is a nice looking kit, and im not rying to crap on your thread, but maybe the lowered the price on it since you bought it or something...
Old 04-18-2013, 10:41 AM   #19
Imarvin240
Trader Rating: (18)
okay, I'm really not in the mood to argue, since I'm at work, so I'll make this simple. The kit you posted has a MUCH smaller intercooler and heat exchanger than the kit I have. The kit you listed isn't able to handle anywhere near the power as the kit I have listed. If that was your confusion, than that is fine. If you care to discuss more, you may feel free to send me a private message.
additional fan $25
ice box $99
Old 04-18-2013, 06:28 PM   #20
Drift_FX
Drift_FX's Avatar
my mistake, i was under the impression it was the same intercooler.... free bumps for you sir.....
Old 04-18-2013, 06:38 PM   #21
Adam496
Adam496 is making a name for him/her selfAdam496 is making a name for him/her selfAdam496 is making a name for him/her self
still have the coil pack gaskets? shipped to 07480?
Adam496 is offline   Reply With Quote
Old 04-19-2013, 10:58 PM   #22
Yuda
Yuda is an unknown quantity at this point
additional fan $25
ice box $99
http://zilvia.net/f/sale-items/51365...-no-mercy.html
look at the third post... no more of this "oh it's cheaper here and here" crap.
and that ACR panel is awesome! my buddy vince has the same setup.
Yuda is offline   Reply With Quote
Old 04-20-2013, 06:05 AM   #23
jlmillionaire
jlmillionaire's Avatar
jlmillionaire is an unknown quantity at this point
Interested in the exhaust mani send me a pm thanks
jlmillionaire is offline   Reply With Quote
Old 04-21-2013, 02:02 AM   #24
frost1988
frost1988's Avatar
frost1988 is an unknown quantity at this point
Pm me about the fuse panel.Thank you.
frost1988 is offline   Reply With Quote
Old 04-30-2013, 11:47 AM   #25
Imarvin240
Trader Rating: (18)
FINAL BUMP! Parts sold and shipped out, someone come buy the other items!!!
