Old 05-06-2013, 09:50 PM   #1
str33tpr3p
str33tpr3p is an unknown quantity at this point
rb26 idle issue
k so i just replaced the gaskets on my intake manifold i had everything apart turned car back on it idles at 2000rpm and i cleaned the throttle bodies cause i thought it was carbon build up but turns out its a special wax that makes sure they dont leak air. Only thing ive heard of to reseal them is a tomei butter fly wax which by the looks of it is discontinued so i was wondering if anyone else knew of other products like it so i can get my car back on the road.
any ideas would help thx!
str33tpr3p is offline   Reply With Quote
Old 05-06-2013, 09:53 PM   #2
S12 Drifter
S12 Drifter's Avatar
S12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymore
you should try GTR canada if no one here is able to help you.
S12 Drifter is offline   Reply With Quote
Old 05-06-2013, 09:56 PM   #3
str33tpr3p
yeah i will im a silvia owner but did this for my friend.. i hate rbs lol
Old 05-06-2013, 09:58 PM   #4
S12 Drifter
So, you pulled the intake manifold off to do what exactly? what was it doing before the 2,000 RPM idle?
Old 05-06-2013, 10:00 PM   #5
str33tpr3p
had a coolant leak so replaced all the lines , than gaskets for intake manifold but i cleaned the throttle bodies cause i thought it was carbon deposit build up in them but turns out to be a wax. Car was idling at 950rpm before now at 2000rpm still sounds fine just high rpm i looked into it i know thats the problem just need something else to seal it since the tomei wax is discontinued .
Old 05-06-2013, 10:05 PM   #6
S12 Drifter
Rb26 Throttle Bodies - Forced Induction Performance - Skylines Australia
here you go dont know if it helps
Old 05-08-2013, 10:22 AM   #7
str33tpr3p
I ended up using dry moly film lube i heard it worked so far so good but it back together idles back down at around 1000 rpm. so for anyone that does this in the future this stuff works
Old 05-08-2013, 10:35 AM   #8
S12 Drifter
Thats awesome to hear!
