![]() Join Date: Sep 2011
![]() Feedback Score: 20 reviews
Cooling wiring experienced opinions
excuse me if this is in the wrong section.
does anyone have any experience using this set up? Adjustable Dual Electric Fan Thermostat Kit, w/ relay and AC cir - Enjuku Racing Parts, LLC right now i currently have my efans wired up to 8 gauge wire a switch inline fuse and the battery battery ![]() i dont want to run this micky mouse wiring. i dont know witch route to go does anyone have any educated in put?
GO DUCKS!!!!!!!!! ![]() |
![]() Join Date: Sep 2005
The enjuku price....ridiculous!
I have this unit works great, also has the ability to be manually turned on via A/C button, defrost or a 12v switch. It's not a complicated setup at all either. I would have preferred a solid state relay vs a standard automotive relay. The price listed there...., it should come with two!! My unit is mounted underneath the core support, hasn't had an issue. This unit is being sold elsewhere for less than $50 search more better.
#3 | |
Mine is actually a hayden 3647 summit, jegs etc. Same thing..Mine is from summit.
http://www.summitracing.com/parts/hda-3647 Sent from a Highly Tuned SIII using Tapatalk HD
#5 | |
AFC #1
![]() Join Date: Oct 2003
It has two leads on it for fans. So you can trigger a second. The key thing with this kit is the adjuster. I never needed to adjust it but, the thermistor they use is a better quality than the kits that use the on/off style thermal switch to actually trigger the fans. The thermal switches have a lower service life and if they aren't activating when you want them too you are screwed. My only problem is been finding a good A/C trigger. I don't want to splice the triple pressure switch as recommended in the manual. I was going to use the stock low speed wire but, it doesn't always seem to be on...
I know all the characteristics of a solid state relay, use them for HID quad projectors to h4 with working high and low beams. I know about the leakage as well, I just don't have a battery depletion problem.
I just think it would be more durable, when sliding the car around, but that's probably because I only have it zip tied down.
#10 | |
AFC #1
