Old 04-28-2004, 10:44 AM   #1
mykem
mykem is an unknown quantity at this point
headlight beam adjustment on dual projector s13 headlights
one of my headlights is aimed badly, how do you adjust the beam on the projectors? is there an adjustment screw or something? it is for the low beam on the passenger side
mykem is offline   Reply With Quote
Old 04-28-2004, 10:52 AM   #2
kandyflip445
kandyflip445's Avatar
Is this the JDM coupe projectors? It should be some screws regardless. Just find a wall with some flat pavement in front of it and then park ~9ft away and adj. them.
My 240 vBgarage
Old 04-28-2004, 12:05 PM   #3
mykem
yes, jdm coupe projectors, i was not able to locate the adjustment screw, do you know where it is at on the back of the headlight housing?
Old 04-28-2004, 08:17 PM   #4
knightrider
knightrider's Avatar
knightrider is an unknown quantity at this point
there are 8mm bolts iirc on the back, find a wall, park 20 ft away, aim your headlights so that they are just below 0 degrees, general rule of thumb is 2 degrees down angle, so maybe 2 inches below level with the headlights. and righty tighty =down i believe. the low beam and high beam have separate adjustments
Drift_ Into A Mountain
Jim Wolf Technology
Stock CA18DET-SR T25-greddy FMIC-JWT SR Lightened FLywheel-300zxTTclutch-SR20DET JWT tuned Ecu
knightrider is offline   Reply With Quote
