Old 06-03-2013, 07:36 PM   #1
600hpsti
600hpsti is an unknown quantity at this point
Send a message via AIM to 600hpsti
Full ka24det swap
S13 ka24de w/
New piston rings,
New rod & main bearings,
New water pump,
New thermostat,
New oil pump,
Rebuilt s14 head fresh machined with 3 angle valve job, new valves, bc springs, bc retainers and bc 264 cams,
ARP head studs,
Lightweight flywheel,
Spec full face Kevlar clutch (stage 2 rated to 300ft/lbs)
T28 freshly rebuild journal bearing turbo w/ hks internal wastegate
Ssautochrome t2 flange exhaust manifold
3” modified downpipe w/ flex piece
3” custom exhaust w/ apex front section muffler, magnaflow racing cat, and magnaflow muffler
Cxracing front mount w/ blitz bov
Aluminum radiator
Flexalite fans
5spd tranny w/ short shifter
Abs drive shaft
550cc sti injectors
Z maf
Chase bays powersteering kit w/cooler
Ac compressor
Full harness
Enthalpy tuned ecu
Safc neo
Trying to go a different route with a V8 this is my full ka24det swap
$ Make offers / trades
WILL NOT PART OUT
600hpsti is offline   Reply With Quote
Old 06-04-2013, 12:10 PM   #2
OiyItsC4ry
OiyItsC4ry's Avatar
OiyItsC4ry is an unknown quantity at this point
How much shipped to 90249?
OiyItsC4ry is offline   Reply With Quote
Old 06-04-2013, 12:44 PM   #3
ProjectPanda13
ProjectPanda13 is an unknown quantity at this point
Send a message via AIM to ProjectPanda13
What headgasket are you running? Has the motor been broken in, how many miles are on the motor?
Thanks,
-Dave
ProjectPanda13 is offline   Reply With Quote
