Old 04-27-2004, 06:48 AM   #1
c0axiL
c0axiL is an unknown quantity at this point
Send a message via AIM to c0axiL
s13 6 speed internals
I have been wanting to do a 6 speed conversion on my s13. I have been reading and from what I understand the 6 speed sr20 internals fit the 5 speed sr20 housing. Unfortunatly I haven't found where I can get the internals. Does anyone happen to know where I can get them from and possibly how much they cost?
c0axiL is offline   Reply With Quote
Old 04-27-2004, 07:09 AM   #2
kandyflip445
kandyflip445's Avatar
I know that SPL parts carries or can get OS Giken 5-spd gears. You might call them to see if they(or OS Giken) have the 6-spd. I also remember seeing on the HKS site, when they only had a list off ALL the parts they had, having the whole 6-spd transmission. I can't find it on their site now though so you'd have to call them and see.
My 240 vBgarage
Old 04-27-2004, 01:58 PM   #3
brianglawson
brianglawson's Avatar
brianglawson is an unknown quantity at this point
Send a message via ICQ to brianglawson Send a message via AIM to brianglawson Send a message via Yahoo to brianglawson
i would love to do this...technically you could do it for ka's too.....i mean they are the same tranny as an sr's just different bellhousing.....food for thought....
S15 SR20DET Powered, Kouki S14 http://zilvia.net/f/showthread.php?t=578575
brianglawson is offline   Reply With Quote
Old 04-27-2004, 02:16 PM   #4
okashira
okashira is an unknown quantity at this point
No they are completely different trannys, the internals will almost definetly not swap. which means SR only, and you have to use the 6spd case too (which means 6 spd flywheel etc....)
I will be selling a full 6spd swap for s13/s14 chassis w/ swswap soon enough.....
okashira is offline   Reply With Quote
Old 04-27-2004, 02:26 PM   #5
Var
Var's Avatar
Send a message via AIM to Var
you can do a 6-speed internals into an sr tranny, then put it on your KA with the KA bellhousing
Hi
Old 04-27-2004, 03:32 PM   #6
okashira
proof?
the trannies are different manufacturers...
the output shaft is way thicker then the 5 spd...
the flywheel is very different...
the casings are 2 peice instead of 3 pc iirc
Old 04-27-2004, 03:35 PM   #7
Var
Var's Avatar
I dont have proof BUT ...The Z32 and Sr20(s13 for sure) transmission are said to fit on the KA engine as long as you keep the bellhousing from the KA. Mounting points are said to be the same. As far as driveshaft lengths, i know the sr20 tranny is the same, i dont know about the z32. Output shaft? i dont know.
All statements above exclude the s15 6-speed tranmission. Now someone above said you could swap the internals into the s13 case, so i know the case fits on the KA...the only thing is input/output shafts (splines/diameter) that i'm not sure about.
Hi
Old 04-27-2004, 05:08 PM   #8
brianglawson
ive always been told the ka and sr tranny are the same gears and such....that many parts would interchange...just a few things different
Old 04-28-2004, 08:53 PM   #9
slideways240
slideways240 is an unknown quantity at this point
Send a message via AIM to slideways240
the flywheels interchange as long as the clutch matches the flywheel.i.e.s14 clutch/flywheel into s15.but the transmission housings are way different.the 6speed breaksdown into 3 pieces.someone else can verify,i think the s13/s14's break into 2 pieces.
slideways240 is offline   Reply With Quote
Old 04-29-2004, 01:21 AM   #10
okashira
the clutches do (95% sure) interchange (s13/s14 --->s15)
but the flywheels do not
