Old 04-27-2004, 08:58 PM   #1
chinesemoonchild
chinesemoonchild is an unknown quantity at this point
Send a message via AIM to chinesemoonchild
KA blown KA24E...help?
i have been problems with my 240 '90 I got in an accident and had to fix my front end. I replaced everything including my radiator. Then try to take it for a test drive and then i see smoke coming out of the hood and my radiator fluid was all over the car. I replaced the radiator and secured everything however i still get smoke. I have the feeling it is the head gasket and/or thermostat. Possibly I could have warped my head. I was wondering if anyone knows the cheapest way to fix this.
If anyone in SD can swap a KA24DE into my car in SD please tell me all the wireing would be already done so if you can please contact me.
Also would it be easier to get a new head or to rebuild the one i currently have?
chinesemoonchild
chinesemoonchild is offline   Reply With Quote
Old 04-28-2004, 05:42 AM   #2
F3600
F3600's Avatar
F3600 is an unknown quantity at this point
Send a message via ICQ to F3600
run the engine and try to find the Exact reason why you see smoke. could be a coolant hose somewhere ... to cheapest way to fix that is to do it yourselve. If you are sure its the head then take it out , go at napa or any other carpart place and give them your head they gonna check it, clean it and shave it for maybe 100 bux ..get a new headgasket and your done !
F3600 is offline   Reply With Quote
Old 04-28-2004, 10:05 AM   #3
nismo1003
nismo1003 is an unknown quantity at this point
depend on what kind of smoke it is , second, do a compression check and check the spark plugs , and check the water level of the radatior ( if u have to refill more often then usual, somwhere is leaking.
nismo1003 is offline   Reply With Quote
Old 04-28-2004, 10:10 AM   #4
nismo1003
if some hose crack and it leak down to the ehxuast manifold or the exhaust area, it does make alot of smoke, but after a while, it's fine....if you are burning radiator fluid , you should see different color smoke came out from the exhaust
Old 04-28-2004, 05:09 PM   #5
sleep
sleep's Avatar
sleep is an unknown quantity at this point
Send a message via AIM to sleep
white/blue smoke = anti freeze
Black smoke = oil
right?
sleep is offline   Reply With Quote
