Old 06-14-2013, 12:12 PM   #1
emoolah
emoolah's Avatar
emoolah is an unknown quantity at this point
rb20 boiling over but not over heating
So far ive changed my thermostat and flush the radiator 5 or 6 times. Car runs fine then boils out of the overflow tank. My oil looks normal coolant had turned red at one point but not since flushing. Blown head gaskest maybe? Im out of ideas
emoolah is offline   Reply With Quote
Old 06-14-2013, 12:17 PM   #2
S12 Drifter
S12 Drifter's Avatar
S12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymore
take the radiator cap off and start car cold if water shoots out could be a blown H/G or bad waterpump.
buy a pressure tester and hold the system at 15PSI dont go more then this because you might break something, let it sit for an hour, if it drops pressure you have a internal leak somewhere.
compression test your engine. when was the last time you replaced the water pump? how old are the radiator hoses?
did you BURP the system? is your coolant temp sensor (gauge) reading properly?
Originally Posted by S13slida View Post
Your wife has bigger balls then you.
S12 Drifter is offline   Reply With Quote
Old 06-14-2013, 04:13 PM   #3
emoolah
emoolah's Avatar
Ive started the car with cap off and no coolant shot out. I replaced the water pump last year. My stock res has a vent in the top. If I run pressure test would it not just come out the vent? My next step was going to replace both temp sensors but now im not sure
Old 06-14-2013, 04:51 PM   #4
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
are you using the stock mechanical fan with shroud or e fans?
GO DUCKS!!!!!!!!!
Juantwo3 is offline   Reply With Quote
Old 06-14-2013, 05:09 PM   #5
emoolah
emoolah's Avatar
Some efans im not sure what kind.
Old 06-14-2013, 07:03 PM   #6
Sileighty_85
Sileighty_85's Avatar
how does the rubber seal on the rad cap look?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-15-2013, 07:11 AM   #7
S12 Drifter
the pressure test would not leak because it's designed to not leak, the stock cap is designed to relieve pressure after 13psi or 16psi depending on cap.
compression/leak down/ pressure test is in order i believe.
Old 06-15-2013, 10:24 AM   #8
emoolah
emoolah's Avatar
Well I took a look today and the color has changed again to rusty red. Wich leads me to believe it is indeed a corroded water pump.
