Old 03-14-2008, 05:41 PM   #1
jspaeth
jspaeth's Avatar
Nismo FPR = Shitty???
I haven't had any real problems with this FPR yet, but prior to purchasing it, I heard they could be a bit touchy.
So, I just got back from the dragstrip....4 runs in a row, I noticed my PFC was registering a maximum knock of 58-60!!!!
Now, I 've been driving the car about a month since it got tuned, and never once had the knock go above 20.
Finally, after 3 runs like this, I decided maybe it's the fuel pressure. Sure enough, I get out, and with the car idling, it's at like 27-28 psi. However, it was tuned with the pressure around 32 psi at idle or so.
So, I raise it up to 33 or so, do a run, and when I get back, it's at 36 psi...
Anyone else having issues with this FPR randomly deciding to be jumpy?
Daily driven
Old 03-14-2008, 05:58 PM   #2
hotlavaflow
hotlavaflow's Avatar
hotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to behold
Send a message via Yahoo to hotlavaflow
Wow I hadn't heard this. That is def not good though. I was thinking of getting one of those.
***Posting to see the responses when they come in***
hotlavaflow is offline   Reply With Quote
Old 03-14-2008, 06:02 PM   #3
s13drob
s13drob's Avatar
Trader Rating: (29)
s13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymore
Feedback Score: 29 reviews
try and get ahold of where you got it and refund that bitch. get a new 1. nismo shouldnt be havin that problem. ITS NISMO. its defected and they should replace it HOPEFULLY.
s13drob is offline   Reply With Quote
Old 03-14-2008, 06:06 PM   #4
GSXRJJordan
GSXRJJordan's Avatar
I was looking for an adjustable FPR and got lucky - I found a Supra guy parting out his fuel system and got a huge Aeromotive dual AN-8 input w/boost ref (vacuum source) for $100. Its rock solid.
That being said, I've never heard that they're 'bad', only the typical rising-rate vs static FP discussion...
Old 03-14-2008, 06:13 PM   #5
jspaeth
jspaeth's Avatar
I understand what you are saying^.
You would agree, though, that if the vacuum at idle is essentially constant, then the fuel pressure at idle should stay roughly constant. Mine was all of a sudden 4 psi or so lower than before.
Yikes!
Daily driven
Old 03-14-2008, 06:24 PM   #6
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
Well first off you set your base fuel pressure incorrectly, to do it the right way you start your engine and disconnect the vacuum to the FPR and adjust until you get 43psi......period end of story.
The reason you do not adjust FP by vacuum is because there are to many possible varibles in respect to vacuum, i.e. cams, state of tune, timing, worn rings, elevation are all things that can make your vacuum lower.
Old 03-14-2008, 07:22 PM   #7
jspaeth
jspaeth's Avatar
I agree with you completely on this....when I initially set the fuel pressure, I set it out of vacuum to 43 psi.....
However, it is worrisome that with the vacuum at idle essentially constant, the f.p. was 3-4 psi low. Again, vacuum at idle is maybe -20...any deviations I've seen are very, very tiny....not enough to cause a 3-4 psi change in fuel pressure.
Daily driven
Old 03-14-2008, 07:28 PM   #8
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Well then what I would have done with out making anyfurther adjustments to the FPR I would have disconnected vacuum and checked to see if FP was still at 43psi.....If it was not I wouldn't write the FPR off as bad yet, just readjust it without vacuum to 43psi and monitor it.
Old 03-14-2008, 07:31 PM   #9
jspaeth
jspaeth's Avatar
You are COMPLETELY correct.....I wish I had checked the base fuel pressure while I was having it tuned....that was a severe dumbass move on my part.
Daily driven
Old 03-14-2008, 07:34 PM   #10
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
nismo fpr = shit
ive seen tons of em go bad in 2-4 months after install...they dont hold proper psi for shit
do it right...hks -6an adaptor, steel braided lines and a aeromotive fpr w/gauge...worth every penny
Old 03-14-2008, 07:35 PM   #11
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
To bad you didn't that sucks....but the FPR and gauge are also good tunning tools, you can actual loose about 2-3 in/hg (with incorrectly gaped sparks plugs, overly retarded ignition timing, even a misfire will upset your vacuum, and driving to different elevations will make a difference for about ever 1,000ft or so) so its a good little indicator as well.
Old 03-14-2008, 07:36 PM   #12
jspaeth
jspaeth's Avatar
I've got a Marshall gauge, which I am really happy with, but you are right, maybe I will have to switch over to a different FPR.
I just think it's amazing that with all of the high tech stuff that goes into cars, a simple little spring-valve that regulates fuel pressure can be the difference between your car running great and running lean and blowing up.
booo
Daily driven
Old 03-14-2008, 07:37 PM   #13
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Originally Posted by dorkidori_s13 View Post
nismo fpr = shit
I dont know I used one before for about 3 years I didn't once have a problem with it ever, maybe the locknut wasn't properly tightend and it caused a leak I dunno.
Old 03-14-2008, 07:37 PM   #14
916S14
916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known
Just gonna let you know better FPR possibilities for the future, i got a sumit racing FRP and it works great. And UNISA JECS knows his stuff.
916S14 is offline   Reply With Quote
Old 03-14-2008, 07:41 PM   #15
jspaeth
jspaeth's Avatar
That's possible, but I don't see the locknut not being tight causing the threaded adjustment bolt to "back out"
However, you sound like you know better than I
Daily driven
Old 03-14-2008, 09:57 PM   #16
efrain240sx
efrain240sx's Avatar
efrain240sx will become famous soon enoughefrain240sx will become famous soon enoughefrain240sx will become famous soon enoughefrain240sx will become famous soon enough
I'm having kind of the same problem. My fuel pressure is very low 26-28 psi with nismo fpr. So I took it off and put on my stock one which I know that works fine. but even with the stock fpr the pressure still at 26-28 psi. So I'm guessing that it's going to be my fuel pump thats going bad.
efrain240sx is offline   Reply With Quote
Old 03-14-2008, 10:09 PM   #17
jspaeth
jspaeth's Avatar
I wouldn't necessarily say that^
Daily driven
Old 03-14-2008, 10:28 PM   #18
bmx22
bmx22 has a spectacular aura aboutbmx22 has a spectacular aura aboutbmx22 has a spectacular aura aboutbmx22 has a spectacular aura aboutbmx22 has a spectacular aura aboutbmx22 has a spectacular aura about
i have a nismo fpr it changed on me in the begining because the car was not hot when i set it. After pownding the car around i re set it making sure the lock nut is tyte and its been fine for a year.
bmx22 is offline   Reply With Quote
Old 06-16-2008, 09:29 AM   #19
nismostate
Banned from the Marketplace
nismostate is on the path to ruinnismostate is on the path to ruinnismostate is on the path to ruin
Send a message via AIM to nismostate
bringing this thread back.
anyone have problems with nismo fpr leaking AIR? retuned the car and it ran great at 15psi. next day started it back up and it idled like crap, vac went from 15 to 8-6, and would not boost more than 10psi. did a boost leak test and noticed leaks everywhere in the system. fixed all of them and then i noticed air coming out of the nismo fpr. how i know? sprayed soapy water on their and it was bubbling on the back side of the fpr. i also noticed the head part can rotate unlike the stock fpr. looks like it is holding the fuel pressure i want but just leaking air. anyone have input on this?
gt2871
BC stage 2
FAST ems; GM 3 bar sensor
blitz dsbc
nismostate is offline   Reply With Quote
Old 06-17-2008, 03:22 PM   #20
nismostate
bump
anyone?
Old 06-17-2008, 03:38 PM   #21
Dream240
Dream240's Avatar
you're talking about air coming from the backside of the metal casing of the fpr? Could the air be coming from a faulty vaccuum hose?
The onl yI could think you would just all of a sudden get a vaccuum leak like that would be from a faulty hose. Or maybe your FPR got damaged somehow (something whacked it, or rubbed against it, etc.)
Good luck.
Old 06-17-2008, 04:07 PM   #22
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
Nismo FPR yes are very touchy and I have also herard of them going bad.
I suspect that they go bad due to the shitty rubber diaphram inside that gets a hole or corroded due to the shitty gas and then starts rotting/corroding the spring which will cause the fuel pressure to change.
Dump it and get a external FPR !!! IMO
WoolyS14DET is offline   Reply With Quote
Old 06-18-2008, 02:26 PM   #23
nismostate
Good luck.
yea air is coming from the backside. its not coming from the vaccum hose because i replaced the fpr with a stock one and no leaks. there's really nothing to rub/whack it so thats odd too.. it is keeping my fuel pressure at 50psi so im not complaining about the pressure changing, just leaking air. now at wot i dont know if theres any problem because gauge is under the hood. i guess i can log my runs and see if theres a dip in a/f but i doubt it. sucks cause i dynoed the car on 50psi but now im dropping it back to stock pressure. can someone confirm that the nismo fpr "head" can rotate? if so, couldn't i just braze the backside so there's no leaks? or is that going to effect the adjustability of the fpr?
wooly, an aeromotive fpr is probably the way to go but damn i really dont want to spend money on something i have already replaced!! trying to get other things done and this is making me take steps backward.. again.
Old 06-18-2008, 06:54 PM   #24
GSXRJJordan
I feel ya there... I've worked on a car that had one, but I honestly don't remember if it's supposed to rotate/whatever. My intuition says that's not the problem, but if you're not holding boost, it may be.
Old 06-18-2008, 07:13 PM   #25
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Ive had a nismo FPR do this, it leaked where the top part clamps down to the bottom part. My guess is when you installed it, you twisted the top a bit and loosened the clamp. What I had to do is got a pair of pliers and clamped it back down, that made it stop leaking...
CLICK HERE!!!
Old 06-19-2008, 10:19 AM   #26
nismostate
hell yea that's exactly what i wanted to hear. Im gonna try clamping it down and see if it stops the leak. if not, im welding/brazing that bitch. for the love of god i just want to drift!
Old 09-21-2009, 12:34 AM   #27
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
I really hate to bump this, however I seem to be having the same issue. I drove from one gas station to the next, popped the hood, and the pressure had changed. Slightly however. Does this mean the start of a FPR going bad? had it less than a month.
Bigsyke is offline   Reply With Quote
Old 09-21-2009, 02:21 AM   #28
RBSilvia1406
RBSilvia1406 is an unknown quantity at this point
Send a message via AIM to RBSilvia1406
Ya ive heard that the nismo fpr are very touchy n inconsistant from NICO. i, myself am going with an areomotive fpr.
RBSilvia1406 is offline   Reply With Quote
Old 09-21-2009, 03:40 AM   #29
fliprayzin240sx
Check it if its leaking, pressurize the vacuum source on it and see if its leaking. You'll hear it leak at the cap section if it is. I clamped mine down and you could probably JB weld the seem too if it is leaking.
CLICK HERE!!!
Old 09-21-2009, 02:07 PM   #30
rc1honda
rc1honda's Avatar
rc1honda is an unknown quantity at this point
I had a similar problem with my SARD. It was not upping the pressure at a 1:1 ratio with boost and the base pressure was fluxuating . I never noticed it until i had it on the dyno. I just bought a Aeromotive w/ some
-6 line and haven't had a problem since.
rc1honda is offline   Reply With Quote
