Old 06-23-2013, 05:08 AM   #1
yapakanichi
yapakanichi is an unknown quantity at this point
brake upgrade
can you replace the stock s13 BMC with a 300zx BMC while keeping the stock s13 brakes?
yapakanichi is offline   Reply With Quote
Old 06-23-2013, 01:42 PM   #2
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
You can, but why would you?
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 06-25-2013, 08:26 AM   #3
AZSCsideways
AZSCsideways's Avatar
AZSCsideways is an unknown quantity at this point
you can but your brakes will be so on-off its pointless, you wont be upgrading at all because in the end the clamping force of your brakes will be the same.
Admin- AZSupraCentral
AZSCsideways is offline   Reply With Quote
Old 06-25-2013, 09:26 AM   #4
yapakanichi
Well anything will be better than what I have now lol. I have a internally leaking master cylinder.
Old 06-25-2013, 09:33 AM   #5
AZSCsideways
i would either
A: replace the master with a Z32 BMC and start buying up Z32 calipers to put on
B: replace with a stock one for almost nothing if you don't plan on doing Z32 brakes
i wouldn't drive much in traffic with that master and caliper combo...you could end up losing the car over it.
if you want the Z32 master and the stock calipers for what ever reason get the smallest z32 master they have (cant remember the size off the top of my head)
Old 06-25-2013, 11:08 AM   #6
Croustibat
If better means going 100% brake force with a 1/10" pedal travel, then yes, a Z32 BMC will be better.
Old 06-25-2013, 11:31 AM   #7
AZSCsideways
+1
Old 06-25-2013, 01:54 PM   #8
zerodameaon
Just go buy a stock MC, you are better off with a leaking MC than a Z32 MC and stock brakes. Its probably safer for everyone around you as well as long as it is only leaking from the res and not a line.
Old 06-25-2013, 06:02 PM   #9
AdrenalineS14
AdrenalineS14's Avatar
AdrenalineS14 is an unknown quantity at this point
Not trying to be a smartass at all... but how is that being better off, and how is it that a z32 MC on a s-chassis with stock brakes not safe? Really not trying to be a smartasss im just wondering
AdrenalineS14 is offline   Reply With Quote
Old 06-25-2013, 06:11 PM   #10
AZSCsideways
Comes down to its a larger master so it takes a lot less peddle movement to do the same amount of work. At 1/4 peddle the brakes will be fully locked. That is why I said find the smallest z32 master (smallest bore size that is)
Old 06-26-2013, 01:41 PM   #11
40craz
40craz's Avatar
40craz is an unknown quantity at this point
Ok not to jack the thread but wht about using the 300zx brake calipers
40craz is offline   Reply With Quote
