Old 07-26-2013, 12:20 PM   #1
Galaxy _S14
Galaxy _S14's Avatar
Galaxy _S14 is an unknown quantity at this point
95 240sx over heated now won't start..
On my way to work My radiator hose busted. It over heated bas before I could cut it off. Replaced hose filled with water and it turns over try to start but keeps cutting out.. Water in the exhaust but none in the oil? I noticed alot of steam coming from the intake... Intake gasket maybe.. Any help would be appreciated
Sent from my SPH-D710BST using Tapatalk 2
Galaxy _S14 is offline   Reply With Quote
Old 07-26-2013, 01:04 PM   #2
Rich260z
Rich260z is an unknown quantity at this point
Blown headgasket, you probably don't have any compression, or coolant is leaking everywhere in the engine
Rich260z is offline   Reply With Quote
Old 07-26-2013, 01:07 PM   #3
Galaxy _S14
I checked the compression good across all cylinders
Old 07-26-2013, 03:04 PM   #4
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Have you reset the ecu? I overheated once for about 10 seconds, never ran right again, turned out to be the ecu
zombiewolf513 is offline   Reply With Quote
Old 07-26-2013, 03:36 PM   #5
Galaxy _S14
No but it ran half assed for about a mile let of the gas n died.. Turned it over with out the plugs shot water out of the cylinders.. I just took the intake off (a bitch) The gasket broke in 4 places n the intake tunnels are soaked.. On 4 and 2. I don't think the head gasket blew
