OBX RB25DET Turbo Elbow fitment
Well this is not a question just a statement perhaps. I hope this helps out some other fellow rb owners who have steering column fitment problems when doing the rb to s14 swap.
I have my engine (rb25det) mounted on an r33 crossmember into an s14. I had the typical column clearance issues and ended up grinding down the stock elbow. Due to a major leak at the flange i had to change my elbow and got the obx ebay elbow. It has about 1/2" of clearance from the steering column but i did have to widen some of the holes to make this thing align. Hope this helps anyone that needs info on these elbows. I searched for hours and didnt find any input on the fitment or performance of these things. I know the other ebay elbows do not fit and need mods but this thing is like a glow minus the holes lol. If anyone needs more info pm or post here. ![]() Untitled by onedolla99cents, on Flickr ![]() Untitled by onedolla99cents, on Flickr ![]() Untitled by onedolla99cents, on Flickr ![]() Untitled by onedolla99cents, on Flickr ![]() Untitled by onedolla99cents, on Flickr ![]() Untitled by onedolla99cents, on Flickr ![]() Untitled by onedolla99cents, on Flickr ![]() Untitled by onedolla99cents, on Flickr ![]() Untitled by onedolla99cents, on Flickr Last edited by mantas; 12-19-2012 at 10:54 PM.. Reason: Uploaded Pix |
Your mileage may very with this elbow.
For starters the elbow isn't a drop in replacement. Or at least mine isn't. Also the elbow doesn't even come close to fitting around the steering shaft. This is a "OBX" version not the non-OBX version on ebay. But who knows maybe they just copied the "OBX" plate. My setup is S14, RB25DET with R33 crossmember and nismo motor mounts I purchased it from: Super Saver Accessories Home Page And of course they want a 25% restocking fee. ![]() |
![]() I can't get the elbow even on, the wastegate pipe is hitting the steering shaft. It looks like even if I shorten the wastegate pipe I'll still have interference with the main pipe, that'll need to be dented to clear the shaft. |
Odd. May be yours is slightly different because of the mounts or the elbow itself is fucked up. Someone pm'ed me a while back asking about the elbow fitment, the person got the ebay one and said it worked, so i dont know what to tell you but that sucks balls that it does not fit.
#15 |
Shit idk what to tell yah might be the nismo mounts since last i checked they make the engine sit lower or higher, but obviously it would be easier to get some other solution for the elbow than running different mounts.
