Old 05-13-2004, 06:47 PM   #1
pacefarm
pacefarm's Avatar
pacefarm is an unknown quantity at this point
Send a message via AIM to pacefarm
KA riddle me this... harness question..
i got an hks turbo timer type 1, with a feature that measures your 0-60, 1/4 mile, etc. here's the weird pard. the factory service manual says that the vehicle speed sensor wire on the ecu (position 26 on the harness) should be yellow green. on mine, its brown white... tried tapping into that wire, for the speed function on the turbo timer, and nothing happens. turbo timer shows 0 no matter what. i checked the service manuals for the 95 96 97 98 240sx, and the wire position and color is the same. my 97 240 for some reason has a different wire color, and aparently function. btw, its still a ka motor in my car.. i'm stomped.. there are two other wires that are yellow green on my harness, one's for the EVAP canister control valve, the other one's not sure. tried tapping that one, shows speed, but its waay off..... any ideas??? please help!! thanks in advance. and oh yea, btw, i'm not colorblind.
pacefarm is offline   Reply With Quote
Old 05-14-2004, 06:21 AM   #2
pacefarm
pacefarm's Avatar
anyone?
Old 05-14-2004, 07:20 AM   #3
TheSparo
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
TheSparo is an unknown quantity at this point
Send a message via AIM to TheSparo
do you have a purple wire? if so try that one..
89 240 SR powered...
ummm i promise its stock
TheSparo is offline   Reply With Quote
Old 05-14-2004, 07:42 AM   #4
pinoi007
pinoi007 is an unknown quantity at this point
try tapping it from the gauge cluster. Look at page 78 in the Electrical System section of the 97 240 fsm.
pinoi007 is offline   Reply With Quote
Old 05-14-2004, 11:05 AM   #5
pacefarm
pacefarm's Avatar
yea i tried tapping into each one of those wires on the gauge cluster, wires 25 and 26. nothing happened. i'm stomped. actual speedometer on the car works just fine, well so far, i'll probably screw it up after messing with all these wires.... i still have no clue why my harness would be so different from what the fsm shows...
Old 05-14-2004, 11:08 AM   #6
pacefarm
pacefarm's Avatar
purple? isnt that the crankshaft position sensor?
