Old 08-14-2013, 08:41 PM   #1
eclipse stig
eclipse stig is an unknown quantity at this point
FS: 2000 328ci Tastefully modded 7000!!!
This is my fathers car, he I owe him so I thought I'd give him a hand. If you are interested in the car call him or text him at 610-653-two78seven.
Tell him you are from the 240sx forum cause he can't seem to remember zilvia.
Ill get more pics when I change computers.
Trades wise he really doesnt want any trades at all, if you want to give it a shot just PM me and I will show him.
Heres whats done:
Since 203K
UUC full cat back corsa exhaust system
ZHP struts all 4 corners
Eibach Sport lower springs
Hatchkis front and rear sway bars
AFE cold air intake
19" VMR wheels VB3 matt black
M steering wheel
Sport seats
UUC weight shift knob
Beisan Systems Double Vanos Seals repaired
Shift linkage rebuilt
Akebono ceramic brake pads front and rear
Brembo brake rotors front and rear
VDO windshield washer pump and o ring replaced
Front brake calipers repaired
Front brake lines replaced
Front and rear brake pad wear sensors replaced
T.C. rear shock mounts and gaskets replaced
New exhaust gaskets
ATE super blue brake and clutch line fluid
Replaced cabin air filter
Oil and mann filter
Rear sway bar end link replaced
NGK Spark Plugs
Right fender well cover
Serpentine belt replaced
Crankshaft positioning sensor (not installed but comes with car)
New xenon headlight bulbs installed
New wiper blades
ICE i pod adapter
Since 226K
Oil filter housing gasket replace
Oil separator (CCV valve) replaced
Camshaft position (intake side) sensor replaced
Throttle body cleaned and o ring replaced
Fuel pump and filter replaced
New radiator
New water pump
New electric fan and housing
New thermostat
New coolant overflow cap installed
3 new coolant hoses and BMW antifreeze
Front window cowl
Lower intake boot replaced
Clear corners installed
Oil and Mann filter
I was preparing this car for my son to use but he's not interested. Bought himself a Nissan 240sx. So need to sell this one. I'm the third owner. Bought this car from a friend of mine with 202K. He bought it as a used certified car from Daniels BMW. The car comes with the original 16" wheels and tires which I used in the winter. The car is solid and reliable. Paint and clutch are original. As you can see I replaced and fixed most all problem areas in these cars (E46's). I'm sure I missed a few also. I'm asking $7000 now. I say that because I'm not in a hurry to sell. I was asking $7900 but think it would only be fair to drop the price because of a few more items that need to be addressed on the car. Now the bad. The AC quit on me this spring. Was told the AC compressor leaks ($350). The MAF sensor needs to be replaced ( $100 / $200 depending on make) before the next inspection which is due next Feb. These are the major items.
Minor items: Some of the leather seat stitching is coming apart on the passenger front seat, rear wheel speed sensor once in a great while fails and only causes a warning light to come on briefly, left front head light has a bad connection and occasionally goes out ( hope to clean before sale) and finally the right rear tire leaks about 2 psi and day. No surprises here. I have all records since owned plus some from previous owner.
This car is a blast to drive. It currently has around 230K. Handles great and sounds even better. I can also reduce the price of the car by parting most aftermarket items you may not be interested in. If you have any questions or want to have a closer look let me know. I pretty flexible with my time.
First and last picture are older, car has clear lights instead of the orange.
eclipse stig is offline   Reply With Quote
Old 08-25-2013, 10:22 AM   #2
eclipse stig
bumppppppp
Old 08-25-2013, 10:53 AM   #3
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
My jeep is payed off next month and I've been thinking about getting a newer car. It's between this or a new jeep. If I flew out to you would I be able to drive it back to Minnesota?
smoked240 is offline   Reply With Quote
Old 08-25-2013, 12:18 PM   #4
JetS500
JetS500's Avatar
JetS500 is an unknown quantity at this point
+1 for UUC exhaust. one of the best exhausts you can get for the E46,. sounds beastly. GLWS man makes me miss my E46.
JetS500 is offline   Reply With Quote
Old 08-26-2013, 08:03 PM   #5
eclipse stig
It would make it with ease.
Thanks man
Old 09-06-2013, 09:23 PM   #6
eclipse stig
Last bump!!!
