Old 09-08-2013, 04:46 PM   #1
240Z28
240Z28's Avatar
240Z28 is an unknown quantity at this point
KA Average builds
Just making a new thread for no reason to remind myself that I need
Average: 300 rwhp to 350 rwhp, you have to start to expect a little more lag. This is about the perfect "street car" limit. No race gas, just good honest street car fun that is fully capable of bring home a 12 second timeslip on a good run.
Turbo Manifold
T3/T04E .50 Trim compressor, .60 trim compressor housing / Stg 3 (aka TA31) turbine wheel, .48 to .63 A/R exhaust housing. Internal wastegate optional but not recommended.
Downpipe can still be 2.5", but this is as far as I would want to push that.
Front Mount Intercooler (FMIC) It's time to upgrade to a larger front mount as the larger will push more air than the smaller sidemount can cool.
Fuel Control
550cc Injectors
SAFC2 to control your fuel injectors, along with the stock ecu.
MSD BTM At this stage I would be running the BTM to control timing retard.
Reflashed ECU-This can be a DIY thing with Megasquirt Tuning or a JWT.
Z32 Maf is required, as the stock Maf stops being able to read at around 260 rwhp.
Wideband O2 Sensor should be installed for tuning.
Block Internals
This is where I would start to consider it necessary to replace you pistons.
Above Average: 350 rwhp to 425 rwhp
Turbo Manifold
Blow Off Valve
T3/T04E 50 Trim .48/.63 or slightly larger turbo, this is where I would start to make the switch up to an external wastegate. You have the option to reroute it back into the exhaust, or merely "dump" it out into the open. "Dump" is usually a mini exhaust in the form of 1.5" piping routed out to the open.
FMIC Larger is starting to be necessary. Typical for setups from here on, are 12"x24"x3" for the core.
Downpipe 3", at this point I would switch to the larger downpipe. You can probably get away with it at 2.5", but it will be causing a little bit of backpressure. Moving to 3" piping as quickly as possible is what you want though. Usually it is necessary to have the first bend 2.5" to clear the steering shaft though.
Exhaust 3"
Block Internals
At this stage you'll want to "build" or fortify your block to better handle boost. Previous to this you can walk the line, but here and forward I find it necessary to do so.
Forged Rods
Forged Pistons
Stock Crank
Plus your typical rebuild items.
Fuel Control
Standalone fuel management is recommended at this stage in the game and is absolutely necessary at the next. These allow you control not only very large injectors, but the tuner to have complete control over both timing and fuel.
720cc Injectors.
Wideband O2 Sensor is necessary for tuning.
SPEED KILLS!!
Drive a Honda and live forever!!
240Z28 is offline
Old 09-08-2013, 04:47 PM   #2
240Z28
240Z28's Avatar
what just happened
SPEED KILLS!!
240Z28 is offline
Old 09-08-2013, 05:28 PM   #3
Frank_Jaeger
What the hell is going on in here?
Frank_Jaeger is offline
Old 09-08-2013, 05:42 PM   #4
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
TLDR
Cliffs - who gives a fawk
KoukiMonsta is offline
Old 09-08-2013, 06:08 PM   #5
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
whats this i dont even
feito is offline
Old 09-08-2013, 06:10 PM   #6
jr_ss
SAFC? Yeah, that'll definitely give you a reason to replace your pistons...
jr_ss is offline
Old 09-08-2013, 06:29 PM   #7
S14DB
AFC #1
S14DB's Avatar
They make to-do lists for a reason. So you don't have to post random crap like this.
S14DB is offline
