Old 09-22-2013, 02:01 AM   #1
ViorelP
ViorelP is an unknown quantity at this point
Nissan 200sx CA18DET won't start
Hello everyone,
I hope i can explain good enough so that you can understand my problem.
I did something stupid. I wanted to do the sleepy eyes mod, but who explained to me didn't do it right, and i said: well, if that's the way it supposed to be done, let's go...
So, instead leg the wires between the gray relay and properly socket, i made connections between the green socket from the left side and the gray socket number 3 (my fuse and relay box is like this - from left to right- :green relay, green relay, green relay and gray relay. I do not have to blue relay, it is an empty place).
When I put the contact, in the fuse and relay box zone started go out a little smoke. I quickly removed the key and remove the wires (one of them was heated/warmed). Now the car does not start.
I checked fuses, the engine spins but it doesn't start.
What should i do?
ViorelP is offline   Reply With Quote
