Old 05-31-2004, 12:34 AM   #1
Tygma
Tygma's Avatar
Tygma is making a name for him/her selfTygma is making a name for him/her self
SOHC to DOHC
ok so my sohc is dying, and i honestly dont want to put any money into it. i dont think i want to go with SR... lack of funds, for now. I was trying to find a good condition dohc but im just curious on what is necessary on the swap? My motor plans are very vague for now, just trying to gather information on a few ideas i had. Thanks a lot.
My review forum
Tygma is offline   Reply With Quote
Old 05-31-2004, 02:00 AM   #2
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
theres a very good post in the archive section regarding this..and since im nice..here ya go man
http://www.zilvia.net/f/showthread.php?t=33502
its a good place to start.
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 05-31-2004, 05:25 PM   #3
Tygma
Tygma's Avatar
thanks a lot...
wow seems like a lot to do! its certainly my option if im limited on cash, but i mean.. since its replacing a whole heck of a lot, i should just go with a CA or SR then huh. i really cannot make up mind.
My review forum
Old 05-31-2004, 07:12 PM   #4
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
dude, dohc only gets you what 10 hp, not much. either bight the bullet and do sr or stick w a direct swap sohc, warning sr is gonna be pretty expensive. ive been saving up for like a year now and still need tons of shit.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 05-31-2004, 07:27 PM   #5
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
i just finished my friends install of sohc to dohc, first time without a lot of help and good tools.
parts needed:
dohc wiring harness (uncut is easier)
dohc ecu (get ecu that is designed for your tranny
motor
upper radiator hose
dohc intake tube
maf and ignitor (dependso on what you wanna do)
thats basically what you need and some modification to get other things to work.
the dash wiring harness will not work with the ka24de wiring harness, but you can do some splicing of your own. get your sohc wiring harness, cut the middle of all the wires that connect to your dash harness, plut that sohc connector (one that you just cut from your old harness) and splice it with the dohc wiring harness, match all the colors, theres a few wires that wont match up, so just cap those and hide them somewhere for a clean look.
sohc maf/afm and ignitor wont connect to the dohc wiring harness. so you can either source the dohc maf/afm from a junk yard, forums (i found plenty of these on www.freshalloy.com) or you can cut your dohc wiring harness and use your sohc harness, just like you did with the dash harness. do the same for the ignitor.
sohc upper radiator hose gets in the way of the sohc intake tube. so you can either make your own custom intake or use the dohc intake tube, if you use the dohc intake tube, get the upper radiator as well.
power steering bolt up directly so you have to modify it yourself, (not sure where you can do that or how you can as i am still trying to figure something out).
and if you drifted your sohc 240 its a good thing to replace your clutch (if not new) and flywheel. i've been told that the sohc flywheel can't support the 30+ hp increase, but i'm not sure, anyone can confirm this? kthnx.
i think thats about it, you'll love dohc motor compared the the sohc motor (atleast some people). its easier to break loose than the sohc.
oh yea one more thing, 91-93 ka24de have the better cams (247 degrees i believe) compared to the other s14 ka24de.
and if you have free time and still sourcing out parts, you should replace the head gasket, port the intake a little bit, take out the secondary butterfly from the intake tract (upper part of the intake). clean the engine and what not.
have fun with the dohc motor ^^
ps. i'm new to this forum. foudn out abotu this forum through my friend mansoor.... if you went to that tustin market pl. meet on may 30th, i was the green fastback that no one talked to ^^....
WheelsDirty
Old 05-31-2004, 07:29 PM   #6
stinky_180
stinky_180's Avatar
Trader Rating: (26)
some people dont have money, and its 30 or so hp. and its a learning experience when swapping an engine that is cheap.
WheelsDirty
Old 05-31-2004, 08:30 PM   #7
mjjstang
so im saying if you dont have the money stick to the kae, and also I learned all I needed to learn by just swapping my friends ka for another ka of the same variety and im doin alright. all signs point to the kae
Old 05-31-2004, 08:54 PM   #8
FastBack 240
FastBack 240's Avatar
FastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymoreFastBack 240 is not welcome here anymore
Good luck finding a low milage SOHC but thats your best bet.
FastBack 240 is offline   Reply With Quote
Old 05-31-2004, 09:51 PM   #9
Tygma
Tygma's Avatar
sucks because some of think that since i only have 27 posts that im a noob. anyhoooooooooooooooo.. im aware of the gains of the dohc, im not going for anything extreme, shieet. my sohc's timing chain guides are fucked, and i really dont want to replace them (replaced freinds and it was well over 10+hours of labor!) it has high mileage, and blah blah blah. so i'd rather do something that will.. a. Pass smog b. be realiable c. be cheap to purchase and maintain. im aware of pricing for the SR and the CA (of course CA parts isnt AS much as the SR) but i can get a front clip for 2200. thats not including the upkeep and not the 250 to pass it for smog. I also wouldnt like my hood to be popped by some lame-o cop. finding a low-mileage KAe or de would be ideal for me i guess, and thanks for those who contributed to my decision. Now, is there anyone in Norcal willing to help me out with the swap?
My review forum
Old 05-31-2004, 11:30 PM   #10
yacho7
yacho7's Avatar
yacho7 is an unknown quantity at this point
Even if society's jumping off a bridge, it doesn't mean you have to.
yacho7 is offline   Reply With Quote
Old 06-01-2004, 12:59 AM   #11
Ricer240sx
Ricer240sx's Avatar
Ricer240sx is an unknown quantity at this point
Send a message via AIM to Ricer240sx Send a message via MSN to Ricer240sx Send a message via Yahoo to Ricer240sx
thanx guys for the info, i too am gunna do this casue i got a DE-T sittin at my buddies house waitng to go in and i am picking up a 89 hehehe
00 impreza 2.5rs sedan...dd
00 impreza 2.5rs coupe....EJ255, goin rwd!!
Ricer240sx is offline   Reply With Quote
