Old 09-30-2013, 12:43 PM   #1
josh350gt
josh350gt is an unknown quantity at this point
RB Rb25 help!
I have a 93 sil80 with a rb25 several bolton mods.
Issue: this is the second rb25 that ive had the EXACT same issue with.
Problem is ring failure in the #5 and or #6 piston Combined with turbo seal failure BOTH times.
i KNow that RB 20/25 have weak ring lands and i konw that the stock t28 turbos are crap, but what are the chances that the same thing happens 2 times on 2 different motors?
I recently bought another rb25 complete bottom end and decided i would replace the rings and bearings and install it. i have yet to coplete the bottom end when i found that i am plagued with a blown turbo seal AGAIN as well. i never run the turbo over 13 pounds.
i plan to go with a top mounted gt35 turbo and 550cc or 770cc injectors.
i have an AEM afr and an apexi safc to tune with.
stock turbo, injectors, and internals what is causing this?!?!?
boltons are greedy intake manifold, q45 Throttle Body, Fuel Pressure Regulator, GTR fmic, greedy bov, hks intake, electric fan, and manual boost controller.
Help me out!
josh350gt is offline   Reply With Quote
Old 09-30-2013, 01:04 PM   #2
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
The 20 doesn't suffer that weakness. Its the piston design on the rb25. You might be running too much timing. Look into some supertech pistons they might be cheaper than cp pistons. Ditch safc and look into a stand alone or a z32 ecu with a nistune board to get better command of your motor.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 09-30-2013, 01:10 PM   #3
josh350gt
ill check on the timing issue but its the exact same thing on both the motors. i was looking into emanage ultimate. i thought about the nistune but it seemed like too much of a hassle. ive got another full bottom end im replacing the rings and bearings just for now and rebuilding the current bottom end.
Old 09-30-2013, 03:40 PM   #4
Yellow4g63
The emange/piggy back systems are more of a hassle because of the wiring. My friends rb25 when it had stock turbo put down 275whp with bolt on parts @ 12psi. We tried more boost but the only gain was down low but no gain up top. It started to run a little lean too.
91 Nx2000 VVL yo
Old 09-30-2013, 08:09 PM   #5
josh350gt
yea, i was only at 13 lbs and with all the mods listed above. i saw a little bit of oil in my bov outlet, could the messed up compression ring cause oil in the bov or is this strictly from a blown turbo seal?
Old 10-01-2013, 05:38 AM   #6
Yellow4g63
Do you have the breather from the valve cover going back into the intake tube on the turbo? If so that will cause oil to get into the bov/intercooler.
91 Nx2000 VVL yo
Old 10-01-2013, 06:23 AM   #7
OutToWinPAHC
OutToWinPAHC's Avatar
OutToWinPAHC is an unknown quantity at this point
Send a message via AIM to OutToWinPAHC
shame your so far away I have a healthy short block. But I would want to see your AFR numbers on a dyno under load im not a piggy back fan at all
OutToWinPAHC is offline   Reply With Quote
Old 10-01-2013, 07:46 AM   #8
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Feedback Score: 36 reviews
I think it's time to find the rotating assembly from a rb26... Gotta be cheaper than replacing bottom ends. lol
mewantkouki is offline   Reply With Quote
Old 10-01-2013, 10:56 AM   #9
josh350gt
my breather goes out to the catch can and the can is vented to atmosphere instead of recirculated. will an rb26 crank/pistons/rods fit a 25 block?
Old 10-01-2013, 11:33 AM   #10
Bnr32gtr
Bnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enough
I think its the greddy intake manifold I've seen it a ton of times where cylinders 5 and 6 lean way out because of the manifold! Not say that's what happens just putting it out there I think its a mush to have it tuned per cylinder! Just my 2 cents
Bnr32gtr is offline   Reply With Quote
Old 10-01-2013, 11:46 AM   #11
josh350gt
spend 1300$ on an intake mani just to have it blow up my motors!!!!!!!!! well poop!
Old 10-01-2013, 11:50 AM   #12
josh350gt
Will it fit the 25 block?
Old 10-01-2013, 05:22 PM   #13
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
From what I read the rb26 crank will work in the block but you need the rods also.
smoked240 is offline   Reply With Quote
Old 10-01-2013, 07:27 PM   #14
Yellow4g63
Cheaper to buy another 25 block. Rb parts are gold, so are good rb26 cranks.
91 Nx2000 VVL yo
Old 10-01-2013, 08:31 PM   #15
OutToWinPAHC
Selling a 26 crank, rods, block, head.... lol
Old 10-02-2013, 12:15 AM   #16
josh350gt
haha well the pistons ringlands are whats bad on the 25 so id need the pistons too. would i be ok with getting the 26 crank and then doing aftermarket 26 rods and pistons?
Old 10-02-2013, 01:06 AM   #17
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
This is to back up the previous post about emanage being garbage, they are. Buy a proper ECU system or build yourself a Nistune off a Z32 ECU. I had nothing but issues and in the end had to take mine off. As for the ringland issue I still had my stock intake and my ringlands went as well.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 10-02-2013, 10:40 PM   #18
josh350gt
ok so my plan at the moment is 26 crank, aftermarket 26 rods and pistons........WAIT will a 26 bottom end fit on a 25 head?
Old 10-03-2013, 03:23 AM   #19
EvilRB
EvilRB's Avatar
EvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond repute
Send a message via AIM to EvilRB Send a message via MSN to EvilRB
Yes
The 25 and 26 are basically the same block just a few minor differences
Read this: question rb26 internals into rb25 ??? - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Do your research but you can do alot and since you have the spare block you can play around with a few different set ups.
Good luck!
EvilRB is offline   Reply With Quote
Old 10-03-2013, 07:07 AM   #20
OutToWinPAHC
Im pretty sure the 26 crank does not fit the 25 block.... fits a 20, they share the same size rod journals but the main journals are different 20/26 to 25. You can put a 25 head on a 26, 26 head on a 25. 26 rods aka 25 neo rods in a 25.
I think what you need is better management and a fresh bottom end. if your on a budget 26 rods in a 25 with forged pistons and call it a day.
Old 10-03-2013, 11:04 AM   #21
josh350gt
if i get a 26 bottom end i need bigger injectors. sweet.
Old 10-03-2013, 12:53 PM   #22
double zero
double zero's Avatar
double zero is an unknown quantity at this point
so pretty much your turbo killed your engine??
Iam here for the free ethanol!
double zero is offline   Reply With Quote
Old 10-03-2013, 01:28 PM   #23
josh350gt
i think so, is it possible that a blown turbo seal can cause your compression rings to fail?
Old 10-03-2013, 01:53 PM   #24
naCAnItIhS
naCAnItIhS is an unknown quantity at this point
Shouldn't.. A bad ring land is not the rings themselves going bad its the groove in which they sit that cracks and breaks off. Typically pre-detonation causes this. Timing issues and/or not enough octane in your fuel for the amount of timing you are running.
All a blown turbo seal is going to do is spit excess oil everywhere. (intercooler, intake, etc)
naCAnItIhS is offline   Reply With Quote
Old 10-03-2013, 02:51 PM   #25
josh350gt
i definatly have a blown turbo seal and my compression ring is bad in my #5 because compression is down to 30 lol
Old 10-03-2013, 02:52 PM   #26
josh350gt
i always run 93 octane so its got to be a timing issue,causing the engine failure. the car idles super high like 1700-2000 rpm and the afr is all over the place. i blow oil out of the tail pipe and excess out of the bov and in the intercooler and what not. not to mention it smokes like nonstop when in any load at all.
