Old 10-13-2013, 07:23 PM   #1
S13alldayyo
S13alldayyo's Avatar
S13alldayyo is an unknown quantity at this point
Sr20det starting problems....
Okay so I semi finished putting my old swap into my new shell. I was goin to crank it to make sure it cranks fine and oil is pumping to the head (after all the wiring is done ofcourse). So, when I engage the cylinder all the way open, nothing happens. Everything work from the fuel pump to
The headlights and my ecu light turns on. I'm not getting no power to the switch on the starter that engages it, I tested it and got no voltage when I crank it , I'm using the new wiring specialties fully tucked harness. Any thing I should check that's not letting that switch get power? Thanks I'm advance guys! Need to finish my daily!
Sent from my iPhone using Tapatalk - now Free
S13alldayyo is offline   Reply With Quote
Old 10-13-2013, 07:55 PM   #2
S13alldayyo
Anyone
Old 10-13-2013, 08:38 PM   #3
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
check the 75a fuseable link in the engine bay, if it's popped nothing works besides lights and some other survival stuff. also if it's popped recheck all your grounds before you throw a new one in there or it'll just pop again.
pacotaco345 is offline   Reply With Quote
Old 10-13-2013, 08:39 PM   #4
S13alldayyo
That's fuse is good
Old 10-13-2013, 08:43 PM   #5
jscherf92
jscherf92 is an unknown quantity at this point
5 speed? Clutch interlock switch, interlock relay, check grounds.
Auto? Inhibitor switch, grounds.
http://www.nicoclub.com/FSM/240sx/91-94/EL.pdf
Page EL-12 is what you want
jscherf92 is offline   Reply With Quote
Old 10-13-2013, 08:44 PM   #6
S13alldayyo
Thanks!! And 5 speed
Old 10-13-2013, 08:49 PM   #7
jscherf92
no problem, i know the feeling. if the car didnt start as a 5sp theres a chance you wouldnt have a clutch switch or relay, there a few guides on how to override it with a jumper across two wires.
Old 10-13-2013, 08:53 PM   #8
S13alldayyo
I have that blue relay thing so I beleave it's a 5speed original
