Old 10-31-2013, 01:28 AM   #1
VegasDrifterS13
VegasDrifterS13 is an unknown quantity at this point
LSX Parts. CAM, Springs, TB, ECU, Heads
I have some LSx parts, for sale or trade, from a build that halted.
Comp Cams Custom Grind Camshaft. Designed by Martin at Tick Performance.
.618/.589 lift, 233/240 duration, 112+2 LSA. Brand new in box. I paid $400. I will take $350 cash or trade value.
**CAM WAS DESIGNED FOR DRIFTING IN MIND. BROAD TABLETOP TORQUE 400-500RWHP ON RELATIVELY STOCK CONFIGURATION**
Brian Tooley Racing Platinum Dual Spring Kit. Good to .660 lift. Best Springs on the market period. Never one Failure or break in over 7 years in business.
I paid $220. I will take $180 cash or trade value.
"897" ECU. LS1/T56 Firehawk ECU. Very Desirable ECU Capable of Both Cable and DBW programming. $120 Cash or trade Value
78mm LSX cable throttle body w/ tps & iacv intact. $60 cash or trade value
853 Casting C5 LS1 Heads. 27k miles. no rockers, otherwise complete. very clean intake ports, in great shape. $150 cash or trade value
6.0 truck manifolds w/ shields $20 for both
poly t56 trans mount $15 (yes its the one for the swap) $15
t56 shifter $30
Im looking for S13 240sx Hatch Parts in trade. THESE PARTICULARLY:
AERO- Supermade and rocketbunny knockoffs.
SUSPENSION- STANCE COILS, POWER BRACE, STRUT BARS
16X10 STEELIES 5X114.3, OR 5X4.5.
SR20 PARTS, 2 WAY LSD, RACING SEATS, HYDRO HANDBRAKE,
ACCUSUMP, NISTUNE ECU OR ANY STANDALONE, IDK. HIT ME UP. WORST I CAN SAY IS NO.
CALL OR TEXT 970 459 0640
VegasDrifterS13 is offline   Reply With Quote
Old 10-31-2013, 01:44 AM   #2
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
The T56 poly trans mount is that just the piece that bolts onto the transmission or does it come with the actual mount to bolt it to the S chassis as well? Long chance but was just wondering.
Thank you.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 10-31-2013, 02:11 AM   #3
VegasDrifterS13
Originally Posted by tauntdevil View Post
the t56 poly trans mount is that just the piece that bolts onto the transmission or does it come with the actual mount to bolt it to the s chassis as well? Long chance but was just wondering.
Thank you.
its just the trans mount. Not the fabbed crossmember.
Old 10-31-2013, 03:00 PM   #4
VegasDrifterS13
Bump. Bad ass cam and springs here. bump. I need stuff you have.....
