Old 11-21-2013, 05:12 PM   #1
madmanmicah
madmanmicah is an unknown quantity at this point
s13 KA24de WAY TO MUCH FUEL
Ok so I did a head gasket on my KA and the I'm 99% positive my timing is right and when I fired it up my car started dumping fuel. I had fuel spitting out of the headers gasket and the test pipe gasket and a huge puddle at the end of the muffler and I have no clue what it is. Any ideas?
madmanmicah is offline   Reply With Quote
Old 11-22-2013, 10:31 AM   #2
madmanmicah
I'm thinking it's my fuel pressure regulator. And I have a 94 dual cam in my s13
Old 11-22-2013, 10:34 AM   #3
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
Check your injectors
andisan is offline   Reply With Quote
Old 11-22-2013, 02:19 PM   #4
madmanmicah
My injectors are almost brand new. I replaced my stock fuel rail when I did my head gasket because mine was bent but I got the fuel rail from some guy for free and it's been sitting for awhile so that's why I think the regulator is bad. But also what I think might be the problem is I did the timing 180 degrees off. If I did would that cause the problem?
Old 11-23-2013, 02:31 PM   #5
Nissan_Alex
Nissan_Alex's Avatar
Nissan_Alex is an unknown quantity at this point
if the car actually started the timing cant be 180 off, it would throw fuel but would not start if it was 180 off. injectors are your issue, the injector o rings are damaged or the injector itself.
Need work done to your car? Free Diagnoses
Nissan_Alex is offline   Reply With Quote
