Old 06-01-2014, 05:41 AM   #1
jarret95_180sx
jarret95_180sx is an unknown quantity at this point
Unhappy ka24de 3cyl idle, dumping raw fuel into cylinder 2. please help!!!
Hey guys so I bought a 91 180sx with a ka24de last night and when I was looking at it and helping the kid get it running before I bought it or would be misfiring/only running on 3cylinders, flooding cylinder 2, and dumping raw fuel out the exhaust. So we checked plugs they were fine. We checked plug wires they are also fine. So I moved to injectors. I went to an auto wrecker and grabbed an injector from a ka24de out of a early 90's Nissan. The injector looked a little different but I decided to put it in anyways. So I put it in and disconnected the battery to reset the ecu and bam it ran perfect again. So I drive to the gas station at put 50$ premium fuel in. And on the way home it was die and stall out when I engaged the clutch but I assume it was from the bad gas because by the time I got home it was perfect so I shut the car off. I come back out about 30 minutes later and start it and its doing the exact same thing it was before. Running on 3 cylinders, dumping raw fuel out the exhaust because cylinder 2 is being flooded with gas. I really don't know what else to try please help me out!! Could this be a ecu problem?
jarret95_180sx is offline   Reply With Quote
Old 06-01-2014, 08:27 AM   #2
Frank_Jaeger
I'd guess torn injector o-ring.
Frank_Jaeger is offline   Reply With Quote
Old 06-01-2014, 09:23 AM   #3
jarret95_180sx
I put a different injector in
Old 06-01-2014, 11:42 AM   #4
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
I would make sure to get the right injector in it, but making sure the o rings don't get moved as you place it in the fuel rail, I've heard that Vaseline work good to help slide the injectors O rings in place without damage
andisan is offline   Reply With Quote
