Old 01-20-2014, 08:49 AM   #1
Surffer227
Surffer227's Avatar
Surffer227 is an unknown quantity at this point
Ca18det oil feed?
I'm installing a t28 on my ca and were I left off last night was the oil feed line from the block, I'm putting braided lines on it, I followed it to the back of the engine but got lost there n it was getting late anyway, so any help on this? Like a picture or diagram? Mabey just explain how to get to it? Appreciate the help.
Surffer227 is offline   Reply With Quote
Old 01-20-2014, 08:56 AM   #2
ilovecoupes
ilovecoupes's Avatar
ilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to behold
#1 oil feed
#2 oil drain
Honestly, if you just had used google images your question would have gotten answered faster than it took you to write this post.
Shoot To Thrill
ilovecoupes is offline   Reply With Quote
Old 01-20-2014, 09:00 AM   #3
Surffer227
Surffer227's Avatar
I saw that pic but it threw me off cause my alternator is on the opposite side of my engine, and I followed the old hard line to the back of my block, so idk
Old 01-20-2014, 11:34 AM   #4
ilovecoupes
The picture is most-likely from a bluebird, so its in a FWD configuration. Never the less, the oil feed and drain should be in the same spot as your motor.
The only hard line that should go to the back of the engine is for the turbo's coolant line feed.
If its in fact a oil-feed that's going to the rear, either whoever you got the motor from has no idea what their doing, or its a CA18DE and someone taped the oil filter block for a feed.
Shoot To Thrill
Old 01-20-2014, 03:47 PM   #5
Surffer227
Surffer227's Avatar
Just took it apart, it was another coolant line, so why does the braided lines all only come with one coolant line
Old 01-20-2014, 09:04 PM   #6
Surffer227
Surffer227's Avatar
Nvm dumb question, but were exactly does the braided line connect to that coolant line? Do I just cut the hard line and clamp the line on there?
Old 01-20-2014, 10:27 PM   #7
ilovecoupes
The original coolant line should lead to a rubber hose. I put a barb fitting on the end of the line and clamped the rubber feed line onto that.
With the barb fitting attached your coolant line should look like this.
Shoot To Thrill
Old 01-20-2014, 10:43 PM   #8
Surffer227
Surffer227's Avatar
My line has a clamp rather than a barb
Old 01-20-2014, 11:32 PM   #9
Surffer227
Surffer227's Avatar
That's the line
Old 01-21-2014, 08:21 AM   #10
ilovecoupes
In that case, like you said, cut off and leave a small section of your hardline to clamp onto
Or you could just use a double sided barb if your new coolant line is long enough.
Shoot To Thrill
Old 01-21-2014, 08:22 AM   #11
Surffer227
Surffer227's Avatar
I'll try both ways out, thanks guys
Old 01-22-2014, 12:34 PM   #12
Surffer227
Surffer227's Avatar
Well I'm getting a custom line made, -4an isn't to small for coolant right?
Old 01-24-2014, 06:39 PM   #13
ilovecoupes
Plumbing Coolant Lines For A Water Cooled Wastegate & Turbo... - Nissan Road Racing Forums
Shoot To Thrill
Old 01-24-2014, 10:40 PM   #14
Surffer227
Surffer227's Avatar
I made all new custom -4An lines, thanks guys, 1 last question tho is the stock ca oil restrictor (the little box thing coming from the block) enough restriction for a s15 t28 ball bearing?
