Old 01-23-2014, 03:09 PM   #1
s13havok
s13havok is an unknown quantity at this point
s13 low compression
Ok I've got a 91 s13 with a sohc motor in it. I ran a compression test and found out that cylinder 4 is running at 60 psi. The car has an exhaust leak out of the manifold but surprisingly doesn't run all that bad considering. Is there a way to test whether its something other than the exhaust leak causing the low compression? If anyone has any ideas im open to suggestions. thanks
s13havok is offline   Reply With Quote
Old 01-23-2014, 04:40 PM   #2
DJ 21o3
DJ 21o3 is an unknown quantity at this point
Correct me if I am wrong but an exhaust leak should not effect cylinder compression.
DJ 21o3 is offline   Reply With Quote
Old 01-23-2014, 04:53 PM   #3
s13havok
ive been told it does and that it doesnt. Not really sure what to believe. Always thought it didn't make sence. What could cause it?
Old 01-23-2014, 04:55 PM   #4
DJ 21o3
Compression loss is generally from the piston rings not sealing. I have no idea how a manifold leak could possibly cause a loss of compression.
Old 01-23-2014, 05:16 PM   #5
s13havok
Is there a way to test whether it is for sure the rings without tearing down the motor?
Old 01-23-2014, 05:21 PM   #6
Rustys14
Rustys14's Avatar
Rustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of light
Pour a little oil (thicker weight helps) down the spark plug hole and redo the compression test, if you get a higher number its likely the rings. Its that simple
Originally Posted by bossin240 View Post
I have a pretty badass neon.
Rustys14 is offline   Reply With Quote
Old 01-23-2014, 05:23 PM   #7
s13havok
cool ill try that. you wouldnt happen to know how much boost a ka24e can take on stock internals?
Old 01-23-2014, 05:41 PM   #8
Rustys14
Rustys14's Avatar
My old DE made close to 300hp on a stock bottom end with out any problems before I sold it. 350 seems to be about the limit for a reliable stockish KA though and that's pushing it a bit. There is no real boost limit since it really depends on what size turbo you run etc. Remember horsepower (and bad tunes) break motors not boost.
It sounds like your motor is in no condition for boost though and judging from the types of questions your asking you should probably avoid turboing your car until you've done more research and have a better grasp on these things. My advise is to spend your time and money on basic maintenance and get your car reliable before even thinking about boost. A reliable stock single cam in a well sorted chassis will always be way more fun then a haggard unreliable turbo setup. Just my
