Old 02-01-2014, 02:39 AM   #1
sicrx
sicrx is an unknown quantity at this point
wat ka24de parts fit sr20 swap
Sup guys I have a ka24de in my 92 s13 and I was told that some parts can be used for sr20 swap, so far I know the ac and pw steering from ka24de can be used on sr20 and clutch plus flywheel. But what bout the perfomance exhaust and motor mounts . I need to know this bcuz I bought quite a few parts for my ka24de but im in need of more piwer and sr20 sounds best.
VEGAS SUX , dont come live here youll kill urself trust me.
sicrx is offline   Reply With Quote
Old 02-01-2014, 02:44 AM   #2
240boi115
240boi115's Avatar
240boi115 is an unknown quantity at this point
why not just go ka-t?
Originally Posted by 13esim View Post
I'll trade you my 300ZX and my older sister
my 240 broke down..again
240boi115 is offline   Reply With Quote
Old 02-01-2014, 03:40 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Goodluck mating a KA flywheel to an SR. Then good luck mating a KA clutch to an SR flywheel.
CLICK HERE!!!
Old 02-01-2014, 07:20 AM   #4
90S13hatch_tony
90S13hatch_tony's Avatar
Trader Rating: (24)
90S13hatch_tony is an unknown quantity at this point
Feedback Score: 24 reviews
X2 on the flywheel and clutch....will NOT match up
Motor mounts are the same from ka or Sr from my understanding,
Cat back should still fit the same unless somebody shifted the position of the original bolt pattern of your downpipe
Granted if all your parts are for a s13, exhaust and mounts should work
Along with tranny mount and 5 speed driveshaft, maybe a few things I forgot about
90S13hatch_tony is offline   Reply With Quote
Old 02-01-2014, 07:39 AM   #5
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Clearly you have done your research.
Go back and try again.
Old 02-01-2014, 01:11 PM   #6
sicrx
K good I was just making sure of all this info, so I do need an sr20 clutch kit , wat about wire harness and ka24de tranny can I use that to plug n play or do I need sr harness and tranny
Old 02-01-2014, 05:34 PM   #7
brndck
brndck's Avatar
this is exactly what i'm talking about. you have done ZERO research, and just expect us to spoonfeed you. these are REALLY simple questions to find answers to.
Old 02-01-2014, 05:38 PM   #8
g14novak
g14novak is an unknown quantity at this point
You need a usdm 200sx harness and JDM sr harness to splice together. Cut right at the ecu plug on both and match up colors. Easy as pie, I promise.
You can use the KA flywheel and tranny. Only 2 bolt holes are gonna line up. Tighten them to 2x factory spec. 200ft/lbs iirc. Make sure you get a rb20 starter or it's never gonna work tho.
Good luck.
g14novak is offline   Reply With Quote
