Old 12-26-2013, 06:33 PM   #1
INeedNewTires
INeedNewTires's Avatar
INeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond repute
Talking Griffin SuperCOOL Radiator and Flex-A-Lite fans setup! PBM Swirl Tank KA/SR/JZ-S14
rad and fan sold!
Powered By Max Coolant expansion Swirl tank. Gen1 silver with gold foil. no damage. works perfect. Retail: $250 Im asking $100 also have the lower radiator adapter piece for $20
INeedNewTires is offline   Reply With Quote
Old 12-27-2013, 07:35 AM   #2
turbob16ef
turbob16ef's Avatar
turbob16ef is an unknown quantity at this point
Pics of the radiator? And you said fits between the frail rails, as in under rad support or original location?
turbob16ef is offline   Reply With Quote
Old 12-27-2013, 08:53 AM   #3
Silviacraze05jr
Silviacraze05jr is an unknown quantity at this point
some griffin rads are special made, if u have the 3 inch thick core it might be a tight fit for 2jz swap. make sure to get the thinnest fans. anyways, I love gfiffin rads, def helps out with cooling the 2j.
Silviacraze05jr is offline   Reply With Quote
Old 12-27-2013, 01:00 PM   #4
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Pix dude!!!!
Old 01-12-2014, 02:24 PM   #5
INeedNewTires
here are pics!
Old 01-13-2014, 10:46 AM   #6
INeedNewTires
yes it fits in the OEM location, will fit with AC condenser if you move it back (towards the motor) but if you have a 6cyl swap it will be a tight squeeze
thanks dude! yeah this rad works amazingly well!
Pix dude!!!!
just for you bro! haha
Old 01-20-2014, 05:02 PM   #7
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
Still waiting on a PM back about that rad+fans...
omgRWDgoodness! is offline   Reply With Quote
Old 01-20-2014, 05:31 PM   #8
GreenApple
GreenApple is an unknown quantity at this point
I don't understand how the swirl works and it's purpose. Japanese writing don't help eaither lol.
GreenApple is offline   Reply With Quote
Old 01-20-2014, 06:11 PM   #9
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
The picture is self explanatory, to swirl pot makes it where you don't have to "burp" your system. It gets rid of the air bubbles without having to Jack the front of the car up, fill it, let it run, etc, repeat.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
SLiDe_WaYz is offline   Reply With Quote
Old 01-21-2014, 03:02 AM   #10
INeedNewTires
fan pics added to first post.
Old 01-28-2014, 12:17 PM   #11
INeedNewTires
bump, make offer on swirl setup!
Old 02-04-2014, 06:19 PM   #12
crunkride
crunkride is an unknown quantity at this point
That is more of a secondary feature. Its primary purpose is to allow the microscopic air bubbles formed at high heat areas in the coolant galleries (near heads, combustion chamber, cylinder walls) to have somewhere to go, and eventually rise up to the surface (in the swirl pot) and separate naturally via the coolant's own density and gravity. The air bubble-less coolant at the bottom, can then re-feed the system. The microscopic air bubbles can do a lot of damage, obviously raising coolant temps, but also things like cavitation or pitting of material at high flow areas. Excellent buy. Free bump
crunkride is offline   Reply With Quote
Old 03-27-2014, 08:47 AM   #13
alexander240
alexander240's Avatar
alexander240 is an unknown quantity at this point
90$ for the swirl pot.
WTB: Dmax Coupe roof spoiler.
alexander240 is offline   Reply With Quote
