![]() Join Date: Jun 2003
![]() i've got an a exhaust leak i can't track down. i'm wondering if there is something common that breaks that i could start looking for. the noise is coming from somewhere in front of the cat. i can't see any cracks or holes or any large gaps in the gasket. i jacked the car up and looked everywhere i could and saw nothing. all the studs and bolts look fine. it sounds like one cylinder is open, like a slow "pop pop pop" at idle (every cycle, not intermitent). i'm thinking about just getting a new header which should fix the problem, but i really can't afford it (what's a little credit card debt).
i'm slightly concerned that there is something wrong with the head because it sounds like the noise is coming from cylinder #4 depending on where you stand. but there is no power loss so i doubt that's it. on a side note, i need to stop jacking up my car, i also found out that i need new tie-rod ends.
![]() Join Date: Apr 2002
you probably have a leak in the gasket that goes from the head to the manifold. get a new one and plop it in there.
Eric
2002 Mazda Protege5 1989 S13 w/SR20DET (sold) |
that's kinda what i was thinking, would i be able to see that at all without taking everything apart?
the noise started all of the sudden at an autoX, not gradually. don't gaskets leaks usually come on gradually?
![]() Join Date: Jul 2003
light a cigarette and hold it around the mani primary. The exhaust leak will blow the smoke from the end of the cig. Just make sure there's no ambient wind or anything.
Drew |
