S14 Fuel Pump Assembly
Hi there, I am having trouble getting the fuel pump assembly out of the tank. I have searched, and threads say it should "slide right up." This is apparently not the case with mine. I can see the metal assembly with the plastic looking thing in the middle of it, and the fuel pump slanted towards the bottom of the tank. However, I pulled on everything inside the tank and it just will not come out.
Is there some type of screw/bolt/clip holding the fuel pump assembly in the tank? And how exactly do I get it out of the tank? Also, can I reuse the O-ring gasket for the tank cap if I ever manage to remove the fuel pump? Thanks. |
![]() Join Date: Mar 2012
there is no bolt, you have to play with it, too bad its not as easy as a s13 tank.
that big o ring should be reusable, its not like the s13 gas o ring that goes out of shape everytime you open it up |
#3 | |
Man w/ CTSV & a Car Seat
