Old 02-08-2014, 10:49 AM   #1
Atill93
Atill93 is making his/her stupidity well-knownAtill93 is making his/her stupidity well-knownAtill93 is making his/her stupidity well-knownAtill93 is making his/her stupidity well-known
s13 is hard to start and eventually overheats
I've recently done a bunch of work on my s13 with a stock ka24
- new fuel injectors
- headers
- emissions deletion
- vacuum line deletion
- walbro 255 fuel pump
- spark plugs and wires
- new ignition switch
- new water pump
the car takes 5-10 seconds to start up. it turns over and over but takes a while to fire up and idle. i have to keep the gas pedal completely depressed and it slowly fires up. this has never been a problem until just last week
after driving the car for 20+ minutes it starts getting hot and steam and eventually coolant starts overflowing out of the top of the coolant over flow tank. she never ran hot before, any idea what might be causing this? my old radiator fan stopped working so i removed it. so now the only fan is the one connected to the water pump. do i need to reinstall new radiator fans?
thanks
Atill93 is offline   Reply With Quote
Old 02-08-2014, 11:38 AM   #2
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
Coolant temp sensor could probably be the issue.
Dboyizmlg is offline   Reply With Quote
Old 02-09-2014, 09:00 PM   #3
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
Over heating = air is still in the cooling system. You need to bleed REALLY GOOD.
You mention that you have the ka24, is it the e or de? I'm going to assume it's de.
Are you sure that the gas peddle needs to be completely pressed down while attempting to start the car? Can you start the car by slightly pressing the gas peddle? What was the reason for changing the fuel injectors?
S13 coupe, KA-t
kruked is offline   Reply With Quote
Old 02-10-2014, 01:52 PM   #4
Atill93
Okay i'll bleed it again. i did notice when i removed the radiator cap a bunch of air rushed out. i'll make sure to try and get all of the air out
and yeah its a ka24de. just started her up and the gas pedal basically has to be fully depressed and it takes about 10 seconds to slowly fire up
i was having issues with the car randomly dying and installed some refurbished injectors. the car ran fine for a while (started strong etc.) but recently its been increasingly difficult to fire up
Old 02-11-2014, 11:09 PM   #5
Atill93
figured out the reason it was hard to start...
leaky/worn out o-ring on cylinder number one, and a leaky fuel hose. got those sorted out and fuel pressure was back to normal and she starts up fine now
still keeping an eye on the coolant/temp
primary concern now is an uneven idle, and a little lag in the throttle response
Old 02-12-2014, 01:46 PM   #6
frankies1390
frankies1390 is an unknown quantity at this point
check idle air control valve, if youve had a bad o-ring then lots of fuel was in your intake manifold. then when mixed with combustion/heat then u get lots of carbon build up. pull or clean the IACV should help.
frankies1390 is offline   Reply With Quote
Old 02-15-2014, 08:14 PM   #7
Atill93
awesome thanks.
Old 02-15-2014, 08:20 PM   #8
Atill93
My car is still overheating!!
i've bled it numerous times now
i've replaced the water pump, and thermostat
the car heats up and then eventually starts blowing steam/coolant out of the top of the coolant overflow tank.
my only idea is that im using too much water in the coolant mix and i should just use primarily coolant with a little bit of water mixed in
any ideas what could be causing it to be running hot?
please help
Old 02-16-2014, 01:03 PM   #9
kkaleher
kkaleher's Avatar
kkaleher is an unknown quantity at this point
If your not leaking coolant out somewhere and you keep getting an air pocket and pushing coolant/air out into the reservoir then over heating, it can only be a couple things- 1: HG is leaking compression into the cooling system 2: radiator cap spring is weak and coolant pressure builds up and pushes coolant out. The HG can leak compression out but you not have a dead misfire, white smoke, or oil/coolant mixing, happened to one of my SRs. coolant to water mix should be 50/50 or 70water/30coolant depending where you live for freezing reasons. Improper mixture isnt going to cause your symptoms. id pressure test the system and check for leaks and make sure the upper and lower rad hoses are getting hot (good coolant flow)
S13- 2jz, 370z 6spd, PT6262
Nissan Master/GT-R Technician
kkaleher is offline   Reply With Quote
Old 02-16-2014, 01:08 PM   #10
kkaleher
kkaleher's Avatar
also if you had an injector o-ring leak fuel id change the oil immediately cause it will have a lot of fuel in it which can create a lot of other issues.
Old 02-18-2014, 06:47 PM   #11
Atill93
thanks for the feedback. I'm gonna park the car in my garage for a few weeks until i have more time to compression test it and take a closer look. I'll probably try changing the radiator cap and radiator as well, just in case. and thanks for the heads up on the oil change
Old 02-18-2014, 09:36 PM   #12
shogun!
shogun!'s Avatar
shogun! is on a distinguished road
Change the thermostat and adjust the timing.
My +700hp RS13
shogun! is offline   Reply With Quote
Old 02-26-2014, 11:22 AM   #13
Atill93
i removed the thermostat to take it out of the equation but its still overheating. no visible leaks any where. coolant just eventually boils and evaporates/spills out of the overflow tank
Old 03-04-2014, 12:33 PM   #14
kevbot
kevbot is an unknown quantity at this point
ive run nothing but water on track days without issue. your mix should be fine. only thing to be concerned with your mix, is having too much water and it freezes and expands, cracking things.
kevbot is offline   Reply With Quote
Old 03-05-2014, 06:18 PM   #15
Atill93
did a compression test yesterday and the numbers are
150
140
105
110
looks like i need a new head gasket...
Old 03-05-2014, 06:19 PM   #16
kevbot
ouf.
Old 03-06-2014, 10:10 PM   #17
Strykermcgee
Strykermcgee is an unknown quantity at this point
Explain your method for "bleeding" your cooling system, You may not have gotten all the air out. When I had a KA it was normally a big endeavor to remove all the air. That motor likes to trap air just by the thermostat and prevent proper circulation. Bleeding it on my car normally consisted of running the car while I had the front end lifted up as high as possible. At least a foot or two off the ground from the front bumper.
Strykermcgee is offline   Reply With Quote
Old 03-11-2014, 02:31 PM   #18
Atill93
i used the bleeder screw on the top of the block. tried many different ways of getting the air out
Old 03-11-2014, 02:38 PM   #19
Strykermcgee
That will not be sufficient enough to propely bleed your cooling system. You will need to use my method exlained above
