Old 04-19-2014, 07:33 PM   #1
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
s13 HELP: Wheel Shakes at idle when power steering is connected VIDEO INCLUDED
Hey Guys,
Ran some custom PS lines with AN fittings on the pump and rack side of the HP hose and rack side of the reservoir return, res to pump is the factory line. The PS rack hard lines were replaced with used lines and have no kinks. All the threads were sealed with high pressure sealant.
When I drive it with no HP line connected it manually turn fine, same with the accessory power on and no engine, it turns with no hesitation too. Turn the car on no problem, try to turn the wheel and VIOLENT SHAKE, rev and it stops.... I am stumped!
Please help!
Here is the video:
Embed isn't working:
https://www.youtube.com/watch?v=RMqwEnoaOAI
https://www.youtube.com/watch?v=RMqwEnoaOAI&fs=1&hd=1" width="858" height="508">https://www.youtube.com/watch?v=RMqwEnoaOAI&fs=1&hd=1" />https://www.youtube.com/watch?v=RMqwEnoaOAI">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=RMqwEnoaOAI
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 04-19-2014, 07:51 PM   #2
FourtyKid
FourtyKid's Avatar
FourtyKid is an unknown quantity at this point
OK I saw a video on reddit that had this happening. Here was someone's explanation:
If it's an electric power assist steering system, the power leads to the assist motor were probably reversed. In that case, when torque is applied in one direction, the motor applies assist in the opposite direction, causing an unstable feedback loop.
If hydraulic, probably reversed something in the control valve, causing the same response.
Source: Work for a steering company and have done this on accident with an EPS. China forgets red is + and black is - sometimes.
@s13cole
FourtyKid is offline   Reply With Quote
Old 04-19-2014, 08:30 PM   #3
5280VertDET
Awesome, that makes sense, especially since the engine powers up when steering force increases. However I should add that I have removed the sensor and the apparatus (whatever that thing is that has the sensor).
any idea how to override or disable it?
Old 04-19-2014, 09:45 PM   #4
5280VertDET
Also, FINALLY found this, to essentially confirm FourtyKid's find...
http://forums.nicoclub.com/crazy-pow...t-t406010.html
Turn out they're most likely reversed, will confirm tomorrow.
Old 04-19-2014, 10:54 PM   #5
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
lines are reversed.
rwtf is offline   Reply With Quote
Old 04-20-2014, 11:59 AM   #6
cotbu
cotbu's Avatar
I remember this from a thread on zilvia, that shit cracks me up!
IIRC, The lines were reversed. but this is a not paying attention fail!
Old 04-20-2014, 04:39 PM   #7
5280VertDET
Yup, I am a dumbass... reversed the lines.
Thanks guys, when I search all i found was high speed shaking posts, until the one above...
