Drive shaft support not lining up
So I was trying to install the drive shaft on my 89 240sx, and when I go to put the support bracket that goes around the center bearing, it's not lining up. At all. Is there a trick to doing this that I'm not getting? I have the drive shaft jacked up and into place in the diff and tranny. I'm not very experienced with working on cars either, bit of a noob.
Is it on wrong or is it the wrong part of the mount? It's got 2 pieces, a more round one and one that's more straight I guess you could say. I tried to push it into the trans more and it'll turn about an eighth of the way and stop, and doesn't push anywhere
![]() Join Date: Oct 2009
![]() Feedback Score: 8 reviews
You might be able to get play or movement in the engine and trans mounts, even the brackets which mount to the engine from the actual mount, you can play around with all of them and you should be fine. Unbolt and pull the engine forward, or push the engine trans forward, there should be enough play to line everything up with ease.
It's possible you have a s14 driveshaft. The carrier bearing is off slightly between s13/s14
If that's the case contact TreHarris on az240sx.org I know he's looking for a s14 driveshaft and has a spare s13 driveshaft. |
#14 | |
![]() Join Date: Aug 2013
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | ![]() |
#17 | |
Man w/ CTSV & a Car Seat
This is what it probably is, using an auto shaft on his manual. |
#18 | |
![]() Join Date: Jul 2005
I think its just the abs/non-abs mixup. Look how close it is? thats less than an inch of difference, kind of like going non-abs to abs huh? just a guess its not a S14 DS because those have a completely different center bearing placement (it would be blatantly obvious) |
#20 |
looks backwards, thought upside down too, but looks correct that way... I know mine was a pain in the butt to align, loosen trans mount a few turns to make it easy to move.... I fixed mine with a single piece driveshaft
#21 | |
In other words, would the yolk jam into the transmission so far that it could go NO further, and still be misaligned at the center bearing? IN FOR SHOTS OF THE YOLK AT THE TRANS! ![]() |
#22 |
^ and I think we all missed that lol..... Is it bolted to the diff already? if not, same dust cap as in the sr maybe? I have used non abs ds on abs diff... it worked, not ideal, but worked
