Old 05-27-2014, 06:09 PM   #1
silhou
silhou is an unknown quantity at this point
Pretty rad GM LS cooling setup for s chassis
Took notes from stews build and pretty much replicated it. Made all the tanks in house.
Asking 1500
Hot lapped with this setup and it never got above 180 degrees
Setup includes everything you need
Afco radiator
Volvo s60r efan and shroud 3600 cfm
-20an inlets and outlets from cbm
-20 rad hoses
Alper motorsports -4an steam ports plumbed into each corner of cylinder heads with a cross over up front
Slp 160 For standard thermo housing
160 ls2 thermo for -20an housing
Silhouette garage surge tank with moroso cap and all -4an and stainless plumbing going to heads and top of rad
Stainless water feed line plumbed into water pump (comes with water pump) other heater port blocked off
Silhouette garage overflow with all plumbing
Mount for s13 if you want it to lean it forward to clear
silhou is offline   Reply With Quote
Old 05-31-2014, 10:19 AM   #2
silhou
Still have this
