Old 06-06-2014, 08:37 AM   #1
Bonez
Bonez is an unknown quantity at this point
S14 KA-t 95
Car decided to frustrate me, Im leaving monday and dont have time to fool with it, Needs a Throttle position sensor and starter. Located Havelock, NC 28532. Have title. Cannot meet, dont have time. 4500$ Call/text 252646314six, have pics
Rebuilt KA24DE-T has about 1500 miles on it, stock internals. ARP head studs, arp crank n rod studs and Xcessive hard engine mounts ( lowers engine)
head just redone (valve job and milled) 300miles
Garret Turbo
248/248 cams
300z twin turbo 5 speed tranny with Xcessive KA-VG adapter, one peice drive shaft and short throw shifter with Xcessive hard mounts. Also has Xcessive shifter adapter (relocates shifter to stock location)
J30 Limited slip diff
XTD stage 4 clutch with lighten flywheel
Xcessive oil pan with sump,,
Max Pro Coilovers fully adjustable with wrenches
Front mount intercooler (battery relocated to trunk)
turbosmart External waste gate
turboxs manual boost controller
300z front brakes
370cc SR20 injectors rebuilt with flow sheet
255LPH fuel pump (new pick up sock and filter)
ISIS rear adjustable control arms
underdrive pulleys
18" wheels 5 lug conversion
N62 blow through maf
Blow off valve
r-s enthalpy tuned ecu with 2 tunes. 1-370cc inj and 740cc injector(have injectors need installed)
Apexi Neo
HKS Turbo timer
AEM A/F ratio gauge
prosport gauges: boost/oil temp/oil pressure
No power steering or A/C.
interior looks good no headliner,
comes with extra heads and stock tail lights.
Bonez is offline   Reply With Quote
Old 06-11-2014, 08:46 AM   #2
eric0191
eric0191 is an unknown quantity at this point
Sent you a PM
eric0191 is offline   Reply With Quote
