Old 06-24-2004, 06:51 PM   #1
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
Black Smoke with catch can! HELP problems! (pix)
Iv had some big problems with my car idling, like it has a vacuum leak or something...changed all my vacuum lines and nothing, still idles the same.
I finally found out why my car idles so badly, it was becuase my oil catch can was not in a loop, it was off the valve cover T to open atmosphere. With this set up my car idles really badly. (jumps from 1000 rpm to 300rpm then dies)
With some tinkering, and looking at some pictures on the internet, i decided to put the open atmosphere side of my oil catch can into my intake (got this idea from the pictures i did all the scribbling on.)
NOW IT RUNS PERFECT!? ----> SIDE EFFECT? Black Smoke all the time from low rpms to high.
Well i dont want any black smoke so i put it back to original set up with open atmosphere(plugged) BACK TO IDLING LIKE CRAP!
Heres the pics, tell what you think and what am i doing WRONG>!??!?!
@woooster on instagram
kuruptR is offline   Reply With Quote
Old 06-24-2004, 08:27 PM   #2
kcolyer27
kcolyer27's Avatar
kcolyer27 is an unknown quantity at this point
Here is mine. HOpe it helps. Catch tank is taht circular thing up front
kcolyer27 is offline   Reply With Quote
Old 06-24-2004, 09:43 PM   #3
kuruptR
kuruptR's Avatar
does your second line go into the intake? if so thats how mine was, then my motor started smoking.
Old 06-24-2004, 11:03 PM   #4
89s132b
89s132b is an unknown quantity at this point
Mine is set up just like your first pic. I don't get any smoke. Try setting it up like 2nd pic but with a breather (small cone air filter) instead of just blocking it off.
89s132b is offline   Reply With Quote
Old 06-25-2004, 02:46 PM   #5
kuruptR
kuruptR's Avatar
can any one explain why it would cause my motor to smoke?
