Old 06-15-2014, 05:22 PM   #1
FourWeeks
FourWeeks is an unknown quantity at this point
Unknown Oil Burning Issue
Need help diagnosing a problem. My SR is shooting white and blue smoke out the exhaust when I'm cruising, never when I'm idling. Doesn't smell sweet at all so I don't think it's coolant, definitely oil and some vapor.
I have done a compression test with 140 across all cylinders and a leak down test showed everything was below 10%. I have replaced the valve seals and I got a used t28 to replace my turbo because I thought it was blown. Pulled off my downpipe and there is no oil so it's probably not a blown turbo.
Wtf could it possibly be???
FourWeeks is offline   Reply With Quote
Old 06-15-2014, 05:33 PM   #2
cbeuglas
cbeuglas is an unknown quantity at this point
Check pcv valve on valve cover. Also could be rings but your compression seems OK . To do compression only crank over 5 times full rotation.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
cbeuglas is offline   Reply With Quote
Old 06-15-2014, 05:43 PM   #3
FourWeeks
PCV valve still rattles so I don't think that's it. I've done a compression test along with my tuner and another shop and both have said that my numbers were fine.
Old 06-15-2014, 06:13 PM   #4
Primo's Silvia
Primo's Silvia's Avatar
Primo's Silvia is an unknown quantity at this point
Oil catch can?
Primo's Silvia is offline   Reply With Quote
Old 06-15-2014, 06:16 PM   #5
FourWeeks
I've thought about putting one on, but I could never decide where I would put it. Where do you have yours?
Old 06-15-2014, 06:31 PM   #6
cbeuglas
Catch can runs from diver side valve cover to catch can the the other side of catch can to the intake.
Old 06-15-2014, 07:27 PM   #7
FourWeeks
Yeah that's what I figured. I have my valve cover teed off on the right side so I think I'll run it in line with the stock air oil separator. Doubtful it will clear up my issue but I guess it doesn't hurt to try.
Old 06-15-2014, 08:58 PM   #8
cbeuglas
My opinion is the intake creates a vacuum to release head pressure and the catch can will catch the oil. A good catch can should keep things working as they should.
Old 06-15-2014, 08:59 PM   #9
cbeuglas
Cheapest place to start is best in trouble shooting.
Old 06-15-2014, 10:37 PM   #10
lansleepxces
lansleepxces is an unknown quantity at this point
lansleepxces is offline   Reply With Quote
Old 06-16-2014, 09:58 PM   #11
cotbu
cotbu's Avatar
for the valve cover t and needing a catchcan in the op case would mean that, the oil has to travel all the way through the pipe work, intercooler and intake manifold, sucked into the combustion chamber to the become the, blueish/gray(white) smoke. This is possible, but since there is no oil in the down pipe.
The op should've looked in the, turbos intake, turbo compressor, hot pipe, cold pipe, intercooler,and intake manifold for signs of oil, this can confirm and eliminate the cause of the smoke. if there is oil? And if there is oil, get to cleaning.
Old 06-17-2014, 12:45 AM   #12
FourWeeks
No oil in piping, but there is residual carbon deposit from when I drove it with the cracked valve seals. I ran seafoam through the throttle body on Saturday and it seemed to reduce smoking to only highway speeds. I'm gonna run seafoam through the brake booster vacuum line as suggested on NICO and report back.
Old 06-17-2014, 12:38 PM   #13
Nikzilla
Nikzilla is an unknown quantity at this point
Gasket?
Sent from my SCH-I545 using Tapatalk
Nikzilla is offline   Reply With Quote
Old 06-18-2014, 01:48 PM   #14
FourWeeks
No loss in coolant.
Seafoam through vacuum line didn't really help. I'll be taking my turbo off and looking at related parts to see if my turbo has blown seals. Tuner took a look at my lines and said my oil feed didn't have a restrictor on it so the oil pressure could have possibly done some damage.
Old 06-18-2014, 03:39 PM   #15
Nikzilla
You could blow a HG without coolant loss if it's only contacting oil channels.
Old 06-18-2014, 05:37 PM   #16
FourWeeks
Wouldn't a blown head gasket reflect on a compression or a leak down test though?
Old 06-18-2014, 08:57 PM   #17
Nikzilla
I'm going to say that "it doesn't have to". Since you have an alluminum block/head, the SR is especially prone to warping. If the deck is warped, but not cracked, you could have oil leaking past only after it's been heat soaked.
Old 06-18-2014, 08:58 PM   #18
Nikzilla
But don't quote me on that. I'm just theorizing.
Old 06-18-2014, 09:14 PM   #19
FourWeeks
Hmm that's interesting. It seems that it does smoke more after it's been running for a while.
Old 06-18-2014, 09:14 PM   #20
Nikzilla
Try to compression test it when it's really hot.
Old 06-18-2014, 09:26 PM   #21
FourWeeks
I've only compression tested it when it was hot. I'm thinking about running thicker oil to see if it stops the problem.
Old 06-18-2014, 10:05 PM   #22
Nikzilla
Do this. Popoff your cold pipe, open the the throttle, and see if there is any oil pooling up in the manifold (I'm assuming you have am S13 SR with the plenum at the bottom)
Old 06-18-2014, 10:09 PM   #23
FourWeeks
I have a blacktop. Am I supposed to be able to see oil inside through the throttle body?
BTW I'm assuming the plenum is the intake mani based on google images lol
Old 06-18-2014, 10:15 PM   #24
Nikzilla
SRs have a 2 part intake. It has the plenum and the runners. The plenum is what the throttle body is conmected to, and it sort of "pools" the air before it goes to the engine through the runners. S14s have plenums at the top, and runners at the bottom. S13s have runners at the top and plenum at the bottom. If there is a lot of blow by, it will blow more oil with it, which gets sucked up by the intake through the pcv and the lines on the exhaust side of the valve cover. If you have a plenum on the bottom, you should easily be able to see if there is any oil build up. Run your car untill it starts shooting blue smoke, then shut it off and take a look.
Old 06-18-2014, 10:50 PM   #25
FourWeeks
Ah okay will do. I might as well check my turbo while I'm at it.
Old 06-19-2014, 02:51 PM   #26
FourWeeks
Checked throttle body and plenum and there wasn't any standing liquid, though it appears there was at one point. Pulled off turbo and there wasn't anything outstanding there either. I'm going to buy a catch can today and see if it fixes anything.
Old 06-19-2014, 03:32 PM   #27
Nikzilla
Did you run it before you checked? Also did you check shaft play in the turbo?
Old 06-19-2014, 03:53 PM   #28
FourWeeks
Yes I drove around for 30 minutes before popping the piping off. There was shaft play on the exhaust side I think, but I read that ball bearing turbos are supposed to have some when there's no oil in there?
Old 06-19-2014, 03:53 PM   #29
Nikzilla
How much shaft play?
Old 06-19-2014, 03:56 PM   #30
FourWeeks
It felt very minimal. I would say less than 2mm
