Old 10-21-2014, 11:40 PM   #1
revolvedspecv05
revolvedspecv05 is an unknown quantity at this point
sr>vq trans adapter. maverick or autotech?
I am switching to a vq trans on my sr, I have the trans now which adapter plate is the question...
Maverick or Autotech?
Just curious about others experience with the products, how well things lined up/quality. ..
Thanks!
Hit em wit it
revolvedspecv05 is offline   Reply With Quote
Old 10-22-2014, 02:15 AM   #2
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
Maverick... I've heard nothing but good things and George is a swell guy
az_240 is offline   Reply With Quote
Old 10-22-2014, 06:14 AM   #3
revolvedspecv05
Any one here running one of these currently?
Hit em wit it
Old 12-02-2014, 08:02 PM   #4
RTB.1054
RTB.1054 is an unknown quantity at this point
Same boat
Thanks!
Im in same boat I have 08 Z33 trans with internal slave cylinder still doing research for my setup, things I learned so far need
A adapter plate
B machine trans bell housing
C trans cross mender
D modify shifter linkage and shifter bracket
E slave cylinder spacer kit for 07 up trans
F clutch line
G drive shaft
H modify trans tunnel
I cut shifter hole farther back
J figure out how to make tach to work
I also would like to hear feedback to see if people think its worth it or not, is it smooth engagement? how's the power band, any weird noise etc. and I heard this guy is sometimes hard to get a hold of.
RTB.1054 is offline   Reply With Quote
Old 12-02-2014, 10:15 PM   #5
ultimateirving
ultimateirving's Avatar
Running it and it fits perfect. Having issues with the oem concentric slave cylinder however. Keeps blowing out. Gone thru two in under 3k miles
Z32 with lq4 swap
Old 12-03-2014, 07:41 AM   #6
RTB.1054
That sucks bro so what is actually happening, is the bearing seizing up? losing line pressure? Did you use that spacer kit ( assuming you have 07 08 trans ) any pics?
I have 98 kouki my baby
Old 12-03-2014, 12:13 PM   #7
TheRealSy90
TheRealSy90's Avatar
They burst when used with a clutch with a stiffer pressure plate than oem. Best bet is to go with the Z1 heavy duty concentric slave cylinder, extremely durable.
Also, i've been seeing stories recently of people's input shaft bearing's going out because of the transmission adapter plates not using dowel pins to center the transmission... So idk what we can do about that.
Such a good signature.
Old 12-03-2014, 06:27 PM   #8
RTB.1054
2 cents
I think it might be an issue because of the spacer did you check to see that the hard line that goes into slave cylinder/ bearing is not cocked? Since the spacer would put it further out of position.
There use to be a recall on 07 and some 08 slave cylinder and I seen them fail if they weren't installed right
Old 12-03-2014, 06:32 PM   #9
Scott@FontanaNissan
Scott@FontanaNissan's Avatar
Scott@FontanaNissan is an unknown quantity at this point
Send a message via AIM to Scott@FontanaNissan
if you are using an aftermarket pressure plate with more than 800kg clamping force you are blowing the seal on the OE CSC. make sure you aren't hyperextending the CSC and if you are within spec let me know. we sell Tilton Race Slave cylinders with adapter plate to replace the shitty OEM plastic peace.
-Juan
Juan Vargas - Motorsports Specialist Fontana Nissan/Nissanraceshop.com
email: [email protected]
Scott's Personal Website/Blog: http://www.scottandkerryann.com
Scott@FontanaNissan is offline   Reply With Quote
Old 12-04-2014, 01:09 PM   #10
ultimateirving
-Juan
Pm sent Juan. I wanna know more about the tilton units
Z32 with lq4 swap
Old 12-04-2014, 05:22 PM   #11
Scott@FontanaNissan
http://nissanraceshop.com/product/z-...rformance-csc/
Old 12-07-2014, 11:07 AM   #12
TheRealSy90
So anybody have info on tearing up the input shaft bearing due to no dowel pins?
Old 12-07-2014, 11:25 AM   #13
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
Subscribed!
Dboyizmlg is offline   Reply With Quote
Old 12-07-2014, 04:04 PM   #14
ultimateirving
No where did you hear this? Ill investigate when i pull the engine again
Z32 with lq4 swap
Old 12-08-2014, 10:14 PM   #15
TheRealSy90
Ugh I can't remember, I came across a post of someone having that problem on another forum.
