Old 01-20-2015, 11:00 PM   #1
Mildviolence
Mildviolence's Avatar
Mildviolence is an unknown quantity at this point
Sr20det will not shut off.
Hey just bought a car with a sr20 redtop engine in it. I am having a issue with the motor shutting off when I shut of the key. The engine and all the dash lights are still on. I tried using kill switch and motor still runs even after switching that off. The only way it shuts off is if I put it in 5th and slowly let out clutch and kill it.
I imagine it is the ignition switch however wondered if anyone else has advice or has seen this problem. Thanks.
Mildviolence is offline   Reply With Quote
Old 01-21-2015, 12:16 AM   #2
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
What electronic devices do you have?
REVIEW
killer240 is offline   Reply With Quote
Old 01-21-2015, 01:39 AM   #3
navans14
navans14 is an unknown quantity at this point
turbo timer
navans14 is offline   Reply With Quote
Old 01-21-2015, 06:36 AM   #4
Mildviolence
No turbo timer. It's a completely stock redtop sr20
Old 01-21-2015, 07:34 AM   #5
blkvrtswp
blkvrtswp's Avatar
blkvrtswp is an unknown quantity at this point
Could be bad diode in the ECU - I've seen it before. I actually have an S13 ECU like that here. Can be fixed if you find someone who knows what they are doing. Pull the fuel pump fuse to shut the engine off.
blkvrtswp is offline   Reply With Quote
Old 01-21-2015, 08:18 AM   #6
Mildviolence
I did remove the ecu and looked for burnt traces and/or components and didn't see anything unusual. I will test the diodes tonight and see if any of them are not functioning properly
Old 01-21-2015, 09:43 AM   #7
Mildviolence
Inspected ecu front and backside of board. No burnt traces. And multimeter shows diodes are working correctly. Any other ideas?
Old 01-21-2015, 12:42 PM   #8
jedi03
I fried ecu once an had that happen...new ecu fixed it
Old 01-21-2015, 01:57 PM   #9
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
With ignition switch OFF, check for voltage at ECU pin 36. If you have 12V there, that wire is being powered from a source other than the ignition switch. That will definitely keep the engine running.
OnTheChip is offline   Reply With Quote
Old 10-15-2017, 10:26 PM   #10
WWWinfernoWWW
WWWinfernoWWW is an unknown quantity at this point
I got same problem on mine, I just put in a different ecu and problem solved, but I still want to fix my old ecu thou, how do you test diodes with multimeter is it just a continuity test ?
Or resistance test ?
If it's resistance how do I know how much each resister has to have
WWWinfernoWWW is offline   Reply With Quote
