Old 01-04-2005, 04:27 PM   #1
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
Would walmart brand 80w90 gear oil cause this..?
Sometimes my car makes a little scrape when i try to put it in gear, i put it cheap gear oil 80w90 from advanced autoparts. Should i put in the expensive stuff, if so what?
sepulchral is offline   Reply With Quote
Old 01-04-2005, 04:41 PM   #2
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
not the wal-mart brand oil by itself, but being a rather old transmission its probably a little bit worn.
My fastback used to grind a little until I put redline fluid in the transmission, my s14 would even grind a little sometimes when I skipped from 3rd to 5th gear,
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 01-04-2005, 05:40 PM   #3
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
Lick Balls Dan.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 01-04-2005, 06:34 PM   #4
sepulchral
Originally Posted by sr240mike
Lick Balls Dan.
Old 01-04-2005, 06:43 PM   #5
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
Lick Balls Dan.
W...T...F...?
Some of the cheaper oils have breakdowns as far as viscosity is concerned in moderate heat ranges. Redline, Royal Purple, and Speed Master oils are what I have used in three different cars with no problems over the last decade.
zero.counter is offline   Reply With Quote
Old 01-04-2005, 06:45 PM   #6
sepulchral
whats the best "Syncro mesh" tranny oil i could use, i JUST put this tranny oil in
Old 01-04-2005, 07:05 PM   #7
SlowCoupe
SlowCoupe's Avatar
SlowCoupe is an unknown quantity at this point
Send a message via AIM to SlowCoupe
i'm using the Pennzoil(sp?) syncro mesh...its in a yellow bottle...works good for me...my tranny has about 150k miles and shifts smooth like butter
SlowCoupe is offline   Reply With Quote
Old 01-04-2005, 07:47 PM   #8
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
my trans has 210 kms on it and its still smooth as glass, sometimes a little clunky when its cold out though.....I change the fluid every year
thing with the cheap stuff is that as long as it has the approval sticker badge thing on it, its going to be just as good as something more expensive. Wal-Mart brand is probably quaker state anyhow- Last time I looked WalMart didnt own any refineries
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 01-04-2005, 10:25 PM   #9
theicecreamdan
Lick Balls Dan.
? do you dislike my sig?
Old 01-05-2005, 03:57 AM   #10
evilimport
evilimport's Avatar
evilimport is an unknown quantity at this point
I'm pretty sure thats what the "lick balls" was for....
You douche bags bring your A-game?
S14 Zenki face owns all.
evilimport is offline   Reply With Quote
Old 01-05-2005, 09:28 AM   #11
Hubie
Hubie is an unknown quantity at this point
Send a message via AIM to Hubie
Umm...it absolutely would make it grind if the back of the bottle said certified up to GL5. Our trannys have to run on GL4. The additive to make it a GL5 may be corrosive to the synchronizers. GL5 is what you want in the differential but not the transmission.
Hubie is offline   Reply With Quote
Old 01-06-2005, 01:02 PM   #12
msaskin
msaskin is an unknown quantity at this point
Send a message via AIM to msaskin
GL5 will eat brass synchros. Avoid it like the plague.
~matt
it's not turbo lag...it's foreplay
'01 Ford Excursion Limited.
Powerstroke Diesel
Coming in spring: ???
msaskin is offline   Reply With Quote
