Old 07-09-2014, 04:59 PM   #1
Grimbrother
Grimbrother's Avatar
Grimbrother is an unknown quantity at this point
horrific noise coming from back of '89 240
https://www.youtube.com/watch?v=MbgWjHRp_6Q&fs=1" width="644" height="390">https://www.youtube.com/watch?v=MbgWjHRp_6Q&fs=1" />https://www.youtube.com/watch?v=MbgWjHRp_6Q">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=MbgWjHRp_6Q
Really only happens after pushing the car on fun streets...
My 240 has a welded diff currently. Could this noise be that? Or could it be a wheel bearing? or something just rubbing something else?
Any help is greatly appreciated,
Grimbrother.
Grimbrother is offline   Reply With Quote
Old 07-09-2014, 10:21 PM   #2
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
I'm assuming it's not the higher pitched 'dun dun dun dun' noise but the kind of clinking/clunking noise? sounds to me like you may need to replace those subframe bushings. Almost like the subframe is sloshing back and forth as you let off and on the throttle causing it to move back and forth making a metal on metal contact to the actual body. Could be wrong, in all actuality it could be a multiple of things...
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 07-10-2014, 10:44 AM   #3
Grimbrother
the wheels no longer rotate together when my friend and i lifted it. each wheel spun independently of the other...
Old 07-10-2014, 10:45 AM   #4
Grimbrother
so i think i broke the welds off the diff.
Old 07-12-2014, 06:10 AM   #5
So Make Like
So Make Like's Avatar
So Make Like is an unknown quantity at this point
looool, my friends diff broke the welds loose a while back and his diff seized. wheel bearing will be more of a deep 'whirring' noise from my experiences.
So Make Like is offline   Reply With Quote
Old 07-12-2014, 08:34 AM   #6
Grimbrother
What makes a diff seize up? It's now leaking diff fluid and covering my back bumper and hatch in oil. Is it now unsafe to drive?
Old 07-12-2014, 08:40 AM   #7
SHIFTrl240
SHIFTrl240's Avatar
SHIFTrl240 is an unknown quantity at this point
So your welded diff is not welded anymore, and you have diff fluid spraying everywhere.
Where is the fluid coming from?
But, yes I would assume it is unsafe to drive.
I think you're pretty lucky it didn't just blow up in the street on you.
SHIFTrl240 is offline   Reply With Quote
Old 07-12-2014, 08:57 AM   #8
Grimbrother
It's dripping out of the differential housing.
Old 07-14-2014, 03:54 PM   #9
RickyS13.
RickyS13.'s Avatar
RickyS13. is an unknown quantity at this point
Just for the record not all welded diffs experience this as I ran mine for 2 years with absolutely no problems.
RickyS13. is offline   Reply With Quote
Old 07-14-2014, 04:06 PM   #10
xoxide
xoxide's Avatar
xoxide is an unknown quantity at this point
Don't worry about it, just keep driving... No big deal.
xoxide is offline   Reply With Quote
Old 07-15-2014, 01:33 PM   #11
Grimbrother
well little update the differential housing has a crack so i at least know where the leak is coming from.
opened up the plugs to drain the liquid and there was barely any in it. also stuck my finger into it and dragged out all these metal bits...
Old 07-16-2014, 09:59 AM   #12
xoxide
xoxide's Avatar
Yep, its common... Just refill the diff and proceed as usual.
Old 07-16-2014, 10:25 AM   #13
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
whatever happened to actually doing shit right and using an LSD?
Old 07-16-2014, 12:07 PM   #14
Grimbrother
i wish the guy had just put on in it instead of doing a shit job welding it. the differential basically screams at me while i drive. going to replace it soon enough.
GRIMBROTHER
Old 07-16-2014, 12:13 PM   #15
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
statement was more of a general tone than directed squarely at you.
but, good bit of advice... get an LSD, especially if daily driving.
Old 07-16-2014, 12:22 PM   #16
Grimbrother
since i've got you here is this LSD any good?
http://www.amazon.com/OBX-Limited-Di.../dp/B00269MIXU
GRIMBROTHER
Old 07-16-2014, 12:25 PM   #17
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
I've daily'd my car with a welded for 4+ years now. No abnormal tire wear, no broken axles, haven't killed myself in the rain, haven't even checked the fluid since I welded it back then. The diff just needs to be prepped properly before it's welded and the car needs to have a halfway decent alignment.
pacotaco345 is offline   Reply With Quote
Old 07-16-2014, 01:58 PM   #18
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
from all the reading i did on the obx units, theyre pretty decent outside of the internal washers (cant remember what theyre called). basically what you want to do if you purchase an OBX unit is have the internal washers immediately replaced with quality units. any transmission shop can do this for you.
what i would recommend you do is save your money and buy a Quaife unit or OEM S15 Helical unit (the s15 unit REQUIRES s15/R34 29 spline output shafts, 28 spline output shafts will NOT work) if youre in the market for a helical diff.
i personally run a helical S15 LSD in my S13... it slides just fine. it doesnt lock up like a clutch type does, but ive yet to have a single issue where full lock is required (helical/torsen dont lock, they just transfer torque as they are a gear base instead of a clutch base). im building my car for reliability and ease of driving, so the HLSD works just fine for me as its 100% silent, maintenance free (outside of changing the gear oil every 20-30k miles) and NEVER wears out!
if you want full lock and something that isnt a pain in the ass driving around town, go buy a 1.5 way or 2 way clutch type LSD from Cusco or Kaaz.
