Old 08-19-2014, 09:46 PM   #1
NB-S13
NB-S13 is an unknown quantity at this point
Angry S13 sr20 swap starter problems!!
We are finishing up my engine swap on my 89 240sx. I put a redtop sr20det in the car. We have it all wired up. When i go to start the car the ACC or clutch p n p relay in the drivers junction block click once but nothing at the starter.
The car had a Wiring Specialties pro series tucked harness for this swap.
Its brand new
I tried messing around the grounds.
We jumped the posts on the starter. It spins but the solenoid wont engage the flywheel.
I understand i may need to replace the starter solenoid.
I just want it to spin by the key!
NB-S13 is offline   Reply With Quote
Old 08-20-2014, 08:58 PM   #2
NB-S13
Solved the problem i guess. Installed a push button
Old 08-22-2014, 12:32 AM   #3
LoganDavenport
LoganDavenport's Avatar
LoganDavenport is an unknown quantity at this point
Having the same problem, i was considering doing a push button. But did you check your clutch interlock switch (located above the clutch pedal) AND your clutch interlock relays? (located in passenger side of engine bay by the battery/ washer bottle neck)
LoganDavenport is offline   Reply With Quote
Old 08-22-2014, 06:05 AM   #4
NB-S13
Yes. They were by passed in the car prior to the swap anyway so i cant see it affecting it now
Old 08-24-2014, 05:55 AM   #5
LoganDavenport
Ever figure this out? My problem ended up being the relay was bad. My switch on the pedal was bypassed but not the relay so might want to double check that? Have you traced the wiring from the start position on the ignition tumbler until you weren't getting any voltage?
