Old 07-07-2004, 10:08 AM   #1
90sr
90sr is an unknown quantity at this point
wont even crank
hey guys, i dont no wat the deal is, sr wont even crank, thought it was cuz the ignitor, and today i jus got it plugged it in, and nothin, i have power but motor wont crank, could use some help, thanks guys.
chris
chris's sr
90sr is offline   Reply With Quote
Old 07-07-2004, 10:29 AM   #2
Eternal_240Sx
Eternal_240Sx's Avatar
Eternal_240Sx is making a name for him/her selfEternal_240Sx is making a name for him/her self
check your starter
Life is good in the bay.
Eternal_240Sx is offline   Reply With Quote
Old 07-07-2004, 10:58 AM   #3
usctom
usctom is an unknown quantity at this point
i had the same problem. Check the connection on the starter,check plugs on tranny harness, or ignition problem. Pretty much anything else it will still crank but just wont turn over
usctom is offline   Reply With Quote
Old 07-07-2004, 11:09 AM   #4
cdlong
check the starter relay (next to the battery) or the clutch pedal switch. start by checking to see if the small wire on the starter is getting power when you turn the key and work backwards from there. also, the big wire should have power all the time.
cdlong is offline   Reply With Quote
Old 07-07-2004, 11:40 AM   #5
90sr
aright i looked at the starter theres 2 plugs going into it, one behind a nut and the other one plugs into it, now the starter relay might be the problem, can you tell me wat the plug looks like cuz im not really sure, jeff from heavy throttle said the same thing, but i dont no wat it looks like so jus let me know thanks .
chris
chris's sr
Old 07-07-2004, 12:33 PM   #6
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
It could be ANYTHING.
You could have borked the wiring.
Your ignitor might be toast.
Your starter might be bad.
You may not have win the wires to the starter or grounded them properly.
Small animals may have laid a curse upon you for not posting this in "tech"...
Anyway, thats my guess. It's any or all of the above.
Check wiring / test ignitor if you can / test starter if you can.
When you turn the key, the starter relay should make a loud clicking sound if its not cranking. That's one way to know its all good.
Good luck
kazuo is offline   Reply With Quote
Old 07-07-2004, 10:35 PM   #7
F3600
F3600's Avatar
F3600 is an unknown quantity at this point
Send a message via ICQ to F3600
Be sure that your engine is GROUNDED. My car was not cranking at first.... i installed a big ass battery cable from the intake manifold to the engine bay and its started right away
F3600 is offline   Reply With Quote
