Old 11-01-2014, 02:39 PM   #1
KingSpence
KingSpence is an unknown quantity at this point
SR20 DOC Race manifold, Tomei m7960 turbo, Turbosmart Ultra-Gate 38mm
Parts are located in Alberta, CANADA. Shipping is obviously available to anywhere in North America.
It's going up for sale, I'm going v8. With this setup I made 355hp/298tq on 14psi with 550cc injectors.
DOC Race manifold: DOC Race makes one the highest quality manifolds you can purchase on the market today. "The DOC Topmount manifold can still be used for streetable vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger T3 frame turbos then the traditional T25 manifold (provided with a t25-t3 adapter). D.O.C. still applies their elaborate porting process to complement maximum flow within ALL of their manifolds."
T3 Flange
2 bolt 38mm Wastegate
Retains AC
SOLD
Tomei m7960 turbocharger: I friggen' love this thing! Quick spooling, puts down awesome numbers and looks amazing under the hood. About 15k, shaft play is damn near identical to when it came out of the box. Good seals, no nicked fins. The internal wastegate has been tacked closed on the outside of the turbine housing. If the buyer wishes they can attempt to grind the tack off and use the internal gate as intended (I recommend keeping the turbocharger externally gated).
I'll also include with the turbo stainless lines, and -AN fittings for both coolant and oil feed/drain. Coolant is -4 and -6, oil is -4 feed and -10 drain.
http://www.enjukuracing.com/products...n-sr20det.html
$sold
Turbosmart Ultra-Gate 38: 38mm external wastegate. 2 bolt style. 7psi spring. These are shorter than Tial wastegates, making installation into tighter area much easier.
$sold
WHOLE PACKAGE: $1100
KingSpence is offline   Reply With Quote
Old 11-01-2014, 04:21 PM   #2
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
Is that a meth kit I see?
Dboyizmlg is offline   Reply With Quote
Old 11-01-2014, 09:41 PM   #3
KingSpence
I don't do meth, that stuff fucks with your brain. That's likely a windshield washer bottle for that oem fresh look.
Old 11-01-2014, 10:57 PM   #4
LongbeachBlue_r32
LongbeachBlue_r32 is an unknown quantity at this point
I'll take the manifold. Pmd
LongbeachBlue_r32 is offline   Reply With Quote
Old 11-02-2014, 09:18 AM   #5
Rambo slice
Rambo slice's Avatar
Rambo slice is on the path to ruinRambo slice is on the path to ruin
nice simple setup glws bump
Rambo slice is offline   Reply With Quote
Old 11-02-2014, 09:48 AM   #6
Rambo slice
what would come with the turbo?
Old 11-02-2014, 11:38 AM   #7
KingSpence
For $550 you get what you see in the picture, plus the internal wastegate if you want to try and make it work. The stainless elbow (I think I still have it), that blue coupler, and the Tomei badge and stickers I have from the original package.
For $600 you get everything above, plus I'll toss in the -AN oil feed and drain lines, -AN coolant feed and drain lines, and respective block -AN fittings.
Old 11-02-2014, 02:03 PM   #8
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Send a message via MSN to Big Zee
love the color of your piping and valve cover!
Two-Tone owner#011509-Lightly Modded
Big Zee is offline   Reply With Quote
Old 11-02-2014, 08:44 PM   #9
cogz756
cogz756 is an unknown quantity at this point
So does this turbo come with everything to hook up?
Sent from my iPhone5 using Tapatalk
cogz756 is offline   Reply With Quote
Old 11-02-2014, 08:58 PM   #10
stevefitter281
stevefitter281 is an unknown quantity at this point
Never seen this setup before! You my friend are awesome! Bump!
stevefitter281 is offline   Reply With Quote
