Brake Light on Dash
Just bought my first 240. The brake light on the dash comes on and fades out. There is also a buzzing that sounds like its comingfrom the top left of the dash when it comes on. (I checked the brake fluid its full. Unplugged the reservoir sensor and its still on) I tried adjusting the tension in the ebrake to see if that helps and its definitely triggering the ebrake sensor. Im completely lost, and checked everything i was told to check.
Any ideas? |
![]() Join Date: Feb 2012
Trader Rating: (37)
![]() Feedback Score: 37 reviews
How would bleeding the brake system make the light stay off?
OP, if you turn the car completely off after shut down, then turn the key to the acc mode w/o completely turning the car on, then turn the ignition system off, does the light still stay on? Have you checked the brake switch on the brake peddle?
S13 coupe, KA-t |
#4 | |
Instagram username:angelmkiv |
Well the brakes seem like they could use a little work. But the light is off with just the key turned on. When I turn the car on, the light comes on. I did see the plug on the reservoir tank looks bad and seemed like there was some fluid around the plug. Idk of that would trigger it or not. And the ebrake switch works. Ive tested that already.
Trader Rating: (37)
Play w/ the plunger in the reservoir. I believe that there is a magnetic sensor on the bottom of it that transmits a signal.
S13 coupe, KA-t |
Okay ill try that. Should I be concerned about the plug and brake fluid around that? The plug looks bad and im thinking it might not be getting a connection if theres a small leak around it
Ok first clean up the master cylinder wiring because that could very well be your problem.you did mention there was fluid around it? Can you pinpoint the leak? Also as for the battery light clean all corrosion on the battery terminals and take your battery to get tested at your local parts store.if the light is still on its your alternator..which again your parts store can test before you buy it
Theres seems to be fluid around the plug on the fluid reservoir. And there isnt any corrosion on the terminals that I see. Im gonna replace the alternator fuse. It looks kinda bad.
A fuse looks kinda bad? A fuse is either working or blown and not functional at all..you should take pictures of what your talking about for us to be able to help you better
Well the top platic cap part on the fuse is broke, and it almost looks as if the metal inside is corroded.but its definitely not the ebrake switch. And the plug on the alternator has a connection. Im thinking its the fluid sensor. The plug looks bad. And if the bul. Check relay is bad, would that cause the lights to come on? Im assuming thats where the buzzing is coming from.
#16 |
I believe the plug that goes into my brake reservoir is toast. If I cut the plug off, and strip the wires and splice them together would that turn the light off? It would technically have its closed connection.
#17 |
![]() Join Date: Jan 2010
![]() Feedback Score: 10 reviews
yo if you still have this problem after all you did with the splicing an the other stuff you did. I would take the dash out but leave it connected, move the wires around an its gonna turn it off. It might just be a wire that was messing up.
The answer is in the math. HP = (TQxRPM)/5252 |
