Old 12-16-2014, 10:11 PM   #1
jaedon
jaedon is an unknown quantity at this point
No Power to accessories
I went to change my ignition switch and the one already in my car had all the wires spliced and wires leading away to a fuse, 2 connectors (both were not plugged into anything) and a ground. I then changed the ignition switch to the new one and tried to start the car and nothing. No dash lights, stereo or anything. Has anybody else had this problem after installing a new one??
jaedon is offline   Reply With Quote
Old 12-17-2014, 03:29 PM   #2
jaedon
Brake lights work, headlights work, no turn signals, clock works, no accessory power to fuses, no power to radio, no power to gauges. Car used to be automatic and now manual. Could it be the car not realizing it's in park?
Old 12-17-2014, 04:12 PM   #3
No 240.. No id
No 240.. No id's Avatar
No 240.. No id is on a distinguished road
Check the auto trans nutral switch jumper. Two brown wires under the fuse box by the battery.
Edit: Nvm, in this case you should have dash light and everything else.
You can sleep in your car, but you can't drive your house.
No 240.. No id is offline   Reply With Quote
Old 12-17-2014, 07:56 PM   #4
jaedon
Update: So far we have found little to no power to ECU leads. Only leads that have power to them are back up power, injector 2 and fuel pump relay. We have no power to the EGI Pump relay
electrical, ignition switch, no power
